Why is my 89 Gutless?
Old May 10, 2010 | 05:40 AM
kenmohr's Avatar
kenmohr
oops sorry ASC automatic spark control.It is by the brake booster. brown and white wire. You will throw a code when it is disconnected (check engine soon) Clear it when done.
Old May 10, 2010 | 06:01 AM
kenmohr's Avatar
kenmohr
Geeze ESC electronic spark control. Sorry I shouldn't comment until after coffee. Behind driver side head. Single wire connector. My base was 1* after tdc. Made a huge difference on gas and power. Now to the coffee pot. It is ready.
Old May 10, 2010 | 07:52 AM
Phantom_Vette1's Avatar
Phantom_Vette1
How do you adjust the tps if it is out? just curious!
Old May 10, 2010 | 10:22 AM
cdig's Avatar
cdig
I did this once on a truck. If memory serves, you just loosen off the two retaining screws and rotate the sensor while monitoring your ohm meter.
Old May 10, 2010 | 10:40 AM
cdig's Avatar
cdig
Awesome, thanks. MMMmmm... coffee...
