Brake Issue
Old May 10, 2010 | 09:50 AM
HdRider04's Avatar
HdRider04
Default Brake Issue
86 Stock
Just started having a brake issue, When I push the pedal it is hard and the glides to a stop, If I drive it a little bit the brakes are better but not what they need to be. Front pads are new ( 2 months) rear are about 50%. Vacuum is fine to the booster, no leaks @ the wheel cylinders, new master cylinder (2months). Check valve on the booster is good.
Booster is not making a whooshing sound when brakes are applied that indicates a bad booster, Could the booster be weak or am I missing something?
Old May 10, 2010 | 10:58 AM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Remove the vacuum hose to the booster and plug it. Carefully drive the car. If it feels the same the booster is bad.
Old May 10, 2010 | 11:03 AM
runner140*'s Avatar
runner140*
Probably need a new brake booster. Your choice is plastic or tin.
Old May 10, 2010 | 12:41 PM
mr.beachcomber's Avatar
mr.beachcomber
If the booster isn't working properly, one other area to check is the vacuum take-off on the intake manifold. I've had problems there before with split hose ends bleeding off the vacuum signal.
Also, check the in-line valve to the booster that protects against backfires. If installed improperly, it would prevent a strong vacuum signal from getting to the booster. Good Luck!
To Brake Issue
