I have my car all tore appart working on the following;
1) Replacing brakes -all four pads & rotors, just stock. Fronts are complete, including flushing the fluid. Rears have to wait until bearings are done.
2) Replacing PS rack. All set to remove except the line -I picked up metric crows foot flare nut set, which looks like the best way to get it out. I am marking the tie rod ends and counting the turns to thread them off -so will it need to be aligned...it is perfect now.
3) Replacing rear bearings. I PB blasted them, but the bolts still seemed too hard to get out, so I PB blasted them again and will try tonight. Can I get to them with my air gun -or just have to "man up" and pull harder?
