Waterspots on Black
Old May 10, 2010 | 02:28 PM
CAJUN C4's Avatar
CAJUN C4
Default Waterspots on Black
What's the best way to rid waterspots from our clear coats. My 96' Black LT4 needs Buffing / polishing etc. What's the best way to get rid or them.
and the best type Buffer ..Orbital or not.Best Compounds in steps etc.?
3-M,Mcguairs or others etc,.
Old May 10, 2010 | 04:28 PM
HlhnEast's Avatar
HlhnEast
Dennis, Ive never used one but I understand claybars work well in bring back the shine to our paint.
You may get a better response at the Car Care Forum here. Go to the drop down forum at the upper left and select "General" then click on the Car Care forum.
Good luck!
Old May 10, 2010 | 04:30 PM
CAJUN C4's Avatar
CAJUN C4
Good luck!
Thanx Steve..as usual.
Old May 10, 2010 | 04:54 PM
LT4BUD's Avatar
LT4BUD
I would start by washing it with Dawn liquid detergent......then use a claybar...
After this prep the car should be ready for whatever wax you choose..
Old May 10, 2010 | 05:56 PM
tblt44's Avatar
tblt44
Mothers sucks
Im looking for a new wax
Old May 10, 2010 | 06:41 PM
DarkBlue88's Avatar
DarkBlue88
From: Charlotte NC, behind someone going 10 under the speed limit
Def claybar it well, I've heard good things about Turtlewax Ice, but haven't tried it.
Old May 10, 2010 | 07:05 PM
Weav's Vet's Avatar
Weav's Vet
You mentioned polishing....Seems like that would remove any water marks. It does when I polish mine. Which BTW it needs now......
Old May 10, 2010 | 07:39 PM
dogfish246's Avatar
dogfish246
Maguires Scratch X works if you dont have too many spots...
Old May 10, 2010 | 09:03 PM
c4cruiser's Avatar
c4cruiser
If you have some waterspots from very hard water or rainwater where the air quality is not good, it may take some serious work to remove them; possibly even a wet sanding with something like a 2000 grit paper and buffing with a professional type of polish. That's lots of work but if the waterspots are deeply embedded into the surface, that may be what you will have to do.
My Silverado is black and it sits outside so waterspots are common. What I have done is to wash the truck with hot soapy water and some white vinegar. I remove tar deposits with something like WD-40 or a good tar remover product. Then wash again.
I have had really good luck with Griot's Garage products and especially with their clay bar. The Meguiar's clay bar doesn't work all that well I use the Griot's clay bar with their "Speed Shine" as the lubricating agent and not soapy water.
After claybar, I will wash the truck again but with less soap, then dry everything with towels. I have one of the older Griot's DA buffers (Porter Cable model 7336 which is actually a sander). Griot's has specially made foam pads for their polish as well as their wax and they are different.
I would recommend using the Machine Polish 3 to clean the surface and remove any swirls or light scratches. After that, you can use their "Best of Show" wax or if you don't want to apply wax 3 times per year, use their Paint Sealant for a long lasting protectant.
Groit's makes some very good stuff but it is pricey compared to other products. They don't do the "one-step" stuff you find at parts stores. There is more work involved to their products, but you can get show-car quality results if you want to do the work.
Go to their web site and look around and request a catalog. Some very neat stuff in there.
Old May 10, 2010 | 10:28 PM
tblt44's Avatar
tblt44
Turtlewax Ice is good on a light color car but my Black vette it.s hard to get the wax off,i never really dries.looks greasy,but stays slick much longer than the mothers I just put in the garbage.
Old May 10, 2010 | 11:57 PM
murray59's Avatar
murray59
Turtle wax makes a black wax. I use it on any darker colored vehicle especially if you don't want deeper scratches looking white from regular wax.
Old May 11, 2010 | 11:08 AM
mcm95403's Avatar
mcm95403
TR3 Resin Glaze is great for things like this! It can also be used to clean/re-polish stainless exhuast and trim and also to polish scratches out or plastic lenses. As per the instructions DO NOT APPLY IN DIRECT SUNLIGHT! Be thing is to wash the car and park it in a garage so that the body is cool. Put the wax on a cloth and use that to spread it on the car. If you squirt it directly onto hot paint you can leave squirt marks (I did it once and was shocked at how quickly it happened). As long as you're careful, it's awesome stuff. You'd be amazed at what it can do for an old, oxidized paint job too.
http://www.amazon.com/Blue-Magic-TR-.../dp/B000BOKO4W
To Waterspots on Black
