Setting Timing Help
Old May 11, 2010 | 11:59 PM
Marv02's Avatar
Marv02
Default Setting Timing Help
Question what wire do I need to disconnect before I set the engine timing with timing light.
Where is the wire and what color is it.
1986 Vett.
Old May 12, 2010 | 02:38 AM
bill mcdonald's Avatar
bill mcdonald
tan wire with black stripe.
Old May 12, 2010 | 08:01 AM
Marv02's Avatar
Marv02
Old May 12, 2010 | 08:09 AM
Muffin's Avatar
Muffin
Your ECM will sense the EST wire is disconnected and set a fault code. After you are done with adjustments disconnect the battery for a minute or so the clear the code.
To Setting Timing Help
