need to replace c4 engine need help
Old May 12, 2010 | 07:15 AM
donkeydawn11's Avatar
donkeydawn11
Default need to replace c4 engine need help
Hi everyone Im at the point of either getting my engine rebuilt for about $2k
I have a 1994 cov corvette with about 165k on it it has a knocking noise coming from bottom part of engine just not long ago I had it diagnosed at a shop.
I just came across this on craigs list would anyone give me your input please.
$1,729.00
Retail $1,929.00
These are excellent entry-level performance engines for older cars, trucks, and street rods. All of the parts in these engines are brand new. These GM Performance Goodwrench 5.7L/350 c.i.d. engines have approximately 8.5:1 compression with an base horsepower rating of 195 hp and capable of up to 260 hp depending on intake and injection setup. These crate engines have a 4.00 in. bore and a 3.47 in. stroke with 4-bolt mains and 2-piece rear main seals. Camshaft specifications are .383 in. intake lift and .401 in. exhaust lift. The open duration is 194 degrees intake and 202 degrees exhaust at .050 in. with a 112 degree lobe separation. The cylinder heads are cast iron with 1.94 in. intake valves and 1.50 in. exhaust valves, 76cc combustion chambers, and 7-bolt style exhaust flanges. These engines include painted valve covers, oil pans, and timing covers. They are drilled for both left hand and right hand dipsticks.
Specifications
4-bolt main with 2-piece rear main seal
Cast iron crankshaft
LT1/LT4 powdered metal connecting rods
Cast pistons (dished)
Hydraulic flat tappet cam (.383''/.401'' and 112° lobe separation)
Cast iron cylinder heads with 76cc chambers
8.5:1 compression ratio
Left and right hand dipstick (Requires 1/2" x 18 Plug for Unused Side - Not Included)
4-quart oil pan
Timing tabs for a 6-3/4'' or an 8'' balancer
Some members told me to get the engine rebuilt because I would know what Im getting but most of the shops that I have talked to wanted around 2k to do the work.
Old May 12, 2010 | 07:54 AM
bjankuski's Avatar
bjankuski
It is not an LT1 engine, it will not work in your application (as a drop in). Have your engine rebuilt.
Old May 12, 2010 | 09:52 AM
toptechx6's Avatar
toptechx6
Ask the shops who quoted you 2K for details on what that includes because it does not sound like enough money to do the job properly.
Old May 12, 2010 | 11:00 AM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
$2k is really cheap unless you're doing the R+R yourself and dropping the engine off at the machine shop.
Old May 12, 2010 | 02:17 PM
383vett's Avatar
383vett
That motor sounds great if you have a station wagon.
Old May 13, 2010 | 01:26 AM
tpi 421 vette's Avatar
tpi 421 vette
sounds like a 195 hp engine
Old May 13, 2010 | 01:35 AM
mnstrlt1's Avatar
mnstrlt1
dude- I've got my Lt1 for sale for CHEAP (complete). It's not a bad idea to get another engine to have rebuilt with the parts you want while you continue driving your car.
*edit*
I think a totally basic rebuild should be less than $2,000 (hyper pistons, reuse of the rods, crank). re-fresh the heads, etc/
Old May 13, 2010 | 01:45 AM
dizwiz24's Avatar
dizwiz24
im assuming the post is a joke because noone who owns and cares about a c4 would put in such a subpar motor.
In fact, even the stock motor is not adequete anymore.
the latest police cruisers (such as caprice ppv) will run circles around our c4s.
do a search on performance features. ported afr 195cc heads, long tube headers, 383 stroker, forged components, forced induction, etc.
may want to go a little lower compression in case you decide to go to forced inductiuon instead of being 'stuck' with high compression n/a.
Old May 14, 2010 | 11:19 PM
mnstrlt1's Avatar
mnstrlt1
Well- it boils down to a budget and need. If his c4 is his daily driver, than down time is a critical factor. For the "average" budget minded individual that just needs to get the car back on the road, a "freshening up" is good enough. Otherwise, it's easy to list "top shelf" parts... we're talking $10k plus for the little list that you put together.
Old May 14, 2010 | 11:43 PM
BAM92's Avatar
BAM92
To need to replace c4 engine need help
