Nuetral safty switch?
Old May 12, 2010 | 04:50 PM
machinegunminky's Avatar
machinegunminky
Default Nuetral safty switch?
Ok a few weeks ago I posted a thread about my '86 having starting issues:
http://forums.corvetteforum.com/c4-t...-stranded.html
It was suggested that it could be the starter. It isnt. Im thinking its the nuetral safty switch now. How do I bypass it or "jump it" as stated?
Old May 12, 2010 | 05:04 PM
powerpigz-51's Avatar
powerpigz-51
On the drivers side kick panel, there are 2 large gauge wires and a connector, I think they are green and yellow or purple....I cant remember exactly. They are twice as thick as the reg wires. Just pull apart the connector and jumper it there with your jumper method of choice. If you decide to replace the switch, it is very hard to get to and you may have to pull out the pedal assembly, as it is clear at the top where you cannot even see it from underneath.
Old May 12, 2010 | 05:10 PM
machinegunminky
That was very confusing...Im sorry but that didnt make much sense to me
Old May 12, 2010 | 05:17 PM
machinegunminky
BTW I climbed underneath and just took this pic of what I believe to be the clutch switch. Its a good half inch from even touching the clutch pedal! Is this wrong??
Old May 12, 2010 | 06:33 PM
powerpigz-51
Minky...,that is not the clutch switch, that is the cruise disengage switch. You will not be able to see the clutch switch. In the area to the left of your feet and up, there should be 2 really thick wires, one is green w/ a white stripe and the other is yellow (you made me go look). Pull the connector (this unhooks the switch) and put in a jumper or cut the connector off and twist the wires together. Good luck.
Old May 12, 2010 | 07:53 PM
machinegunminky
Ok I have the green with white stripe but it looks like its mate is PURPLE could that be what Im looking for?
Old May 12, 2010 | 07:54 PM
jfb's Avatar
jfb
When you unplug the clutch safety switch, put a jumper wire across the two terminals on the plug. Measure the voltage on the jumper wire to ground and try a crank, you should have 12v on the jumper. If you don't, then you may have VATS problems. I will post how to check this when you tell us if you had 12v on the jumper.
Old May 12, 2010 | 08:28 PM
machinegunminky
I cut and spliced and conquered!! Thank you SO much for your help guys!!
To Nuetral safty switch?
