ECT sensor
Old Mar 17, 2002 | 11:28 PM
mayberry's Avatar
mayberry
Default ECT sensor
Pulled the codes on my '89 and got code 15 - ECT snsor indicates low temp, or ECT sensor open. Can somebody tell me what this means and where it is? Any help will be greatly appreciated.
Old Mar 18, 2002 | 10:51 PM
mayberry's Avatar
mayberry
Default Re: ECT sensor (mayberry)
ttt
Old Mar 18, 2002 | 11:26 PM
Black 'n Blue's Avatar
Black 'n Blue
That would be the coolant temperature sensor.
Old Mar 18, 2002 | 11:52 PM
Black85L98's Avatar
Black85L98
I think you know where it is now. The question is what does it do when it goes out.
Are all your plugs tight? :D
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
It's below the throttle body. Could be you knocked the wire off?
How is the car running? Anything else you can tell us?
Pete
Old Mar 19, 2002 | 03:44 AM
pablocruise's Avatar
pablocruise
Default Re: ECT sensor (PeteL)
I know it gets it's reading off another sensor, but what does your dash temp gauge read when the car is running and warm? Is the car running ok?
Old Mar 19, 2002 | 03:52 AM
GlockLT4's Avatar
GlockLT4
Default Re: ECT sensor (89 Paul in cal)
If the sensor is bad or the wiring to the sensor is bad, then the digital dash will show a wrong temperature and possibly run in open lope mode.
Old Mar 19, 2002 | 07:22 PM
mayberry's Avatar
mayberry
The car is idling very poorly. It revs up then down. I have not checked the temp gauge yet but will when I get home. The wire is connected and the connector seemed ok. If the sensor goes out will it cause the car to run poorly like that.
Old Mar 19, 2002 | 09:00 PM
mayberry's Avatar
mayberry
Default Re: ECT sensor (Glock'94)
Car is idling around 1500 RPM now. Coolant temp got to about 185 with an oil temp of 165 while idling. I have not driven it and got it to full operating temp yet. Is there a way to test the sensor?
Old Mar 19, 2002 | 09:20 PM
PeteL's Avatar
PeteL
That sensor has no effect on the guage, it's for the ECM.
Quick Check:
Engine off, disconnect battery negitive cable for a minute or so.
Reconnect battery
Disconnect temp sensor
Short wires on sensor harness connector together using a small jumper
Re-start car and see what code sets
14 = sensor harness OK, check connector and sensor
15= wiring harness has an open circuit
Wiring: Yellow wire +5V from ecm
Black wire = ground
Sensor test:
Degrees___Resistance (OHMS)
160_______450
100_______1,800
70________3,400
40________7,500
20________13,500
0_________25,000
HTH
Pete
Old Mar 19, 2002 | 09:38 PM
mayberry's Avatar
mayberry
Thanks. Got a 14 so now I am going to check the resistance on the sensor and look a little closer at the connector.
Old Mar 19, 2002 | 11:16 PM
Black85L98's Avatar
Black85L98
Sounds like another sensor for you. You should see if you can get a package deal. Let me know if you want some help.
Old Mar 20, 2002 | 12:04 AM
mayberry's Avatar
mayberry
Default Re: ECT sensor (Black85L98)
Pulled the sensor out and shelled out the 12 bucks for a new one and my car is running great. Thanks everybody for the help.
Black85L98
Yea it would be nice if I could get every sensor on a bulk package deal. Looks like I am going to end up replacing them all anyway.
:cheers:
To ECT sensor
