Is your corvette slow?
Old May 16, 2010 | 11:41 AM
94roseman's Avatar
94roseman
Default Is your corvette slow?
Ok i have owned alot of LT1 camaros and trans ams. Now i have a 1994 corvette. The Corvette looks brand new! 100k miles and no problems. Has new opti, plugs, wires, coil, cut airbox, magnoflo w\o resonator, new cats. I could probly get out and go around my car on foot.
The f-bodys i had seem alot "peeper" This car just seem very slugesh. Any ideas on what it may be?
Old May 16, 2010 | 11:55 AM
cv67's Avatar
cv67
St. Jude Donor '05
What rearend gear do you have?
Old May 16, 2010 | 12:02 PM
twin540's Avatar
twin540
auto or manual ?
94roseman's Avatar
94roseman
i have the performance rear 3.07
Old May 16, 2010 | 12:03 PM
94roseman's Avatar
94roseman
auto
Old May 16, 2010 | 12:10 PM
94roseman's Avatar
94roseman
think im going to order headers and gears today!
Old May 16, 2010 | 03:47 PM
EastCoastHD's Avatar
EastCoastHD
Maybe it is slow. Maybe it is not running / tuned properly.
Have you datalogged?
Are you the original owner? Have previous owner(s) been tinkering under the hood?
At 100k, maybe the engine has been run hard / abused. Checked compression? Checked timing? Fuel pressure?
I would check these things first before throwing money / parts at it.
Old May 16, 2010 | 04:50 PM
WW7's Avatar
WW7
This is good advice..WW
Old May 16, 2010 | 05:38 PM
94roseman's Avatar
94roseman
the guy i bought ifrom was 85 yrs old and only put 1200miles on the car in 5 years. The car bone stock to the filter! Today noticed runs way worse when under hafl tank of gas. I checked everything when i did the tune up. I think i will pull the gas tank and clean it out. the fuel filter was clogged up some.
And the parts are not to fix the problem, i just like the way headers sound, and only going to a 3.73 gear.
Old May 16, 2010 | 06:29 PM
pappy.72's Avatar
pappy.72
New fuel filter, new injectors and regular tune up. It will be good as new.
Old May 16, 2010 | 06:36 PM
94roseman's Avatar
94roseman
you think the injectors are bad? can i clean them? I did the tune up, even a new opti. And 2 fuel filters in the last week.
Old May 16, 2010 | 06:44 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Have you checked fuel pressure at WOT?
Old May 16, 2010 | 06:48 PM
94roseman's Avatar
94roseman
No i havent. it does have a stumble able 2500rpms just cruzing down the highway and almost no power about 5000rpms
Old May 16, 2010 | 06:51 PM
The Green Rocket's Avatar
The Green Rocket
All of the above is good advice, plus check exhaust back pressure / catalytic converters. Sitting can be bad on the car, like your clogged fuel filter seem to suggest. For a mini education on injectors: http://forums.corvetteforum.com/c4-t...questions.html
Normally the LT1 is a very responsive engine, even the ones with 2.59 axle ratio - when they have the 3.07 axle ratio and feel like a slug something is wrong.
Thomas
Old May 16, 2010 | 06:54 PM
94roseman's Avatar
94roseman
Well dont think that i hope in it and just started ragging on the car, its not like that just felt weak and when i got into the accelorator it seemed like i went 1/2 just to go 90mph
Old May 16, 2010 | 06:56 PM
Z06X's Avatar
Z06X
Go to the drag strip one day and see if you hit the numbers advertised for the car...or come close even. Seems like the easiest way.
Most people that own these cars thinks they are rocketships, so asking this forum if Corvette's are fast will get pretty predicatable answers. "Fast" is all compared to what your used to. If your used to driving a Dodge Caravan or a Silverado...yes they'll think its fast, even if its running high 14's.
Old May 16, 2010 | 06:59 PM
94roseman's Avatar
94roseman
well i am comparing it to stock camaro's that i have had. There just isnt very much seat of the pants pull in this car.
To Is your corvette slow?
Old May 16, 2010 | 07:16 PM
The Green Rocket
Sometimes the assometer lies. Only way to know for sure is the dragstrip or a chassis dyno. Since the car is new to you it would still be good to go through the above suggestions to make sure all is well and operating as it should.
Thomas
Old May 16, 2010 | 07:25 PM
94roseman's Avatar
94roseman
yeap i agree...what should it run at the 1\4 at a mile high?
Old May 16, 2010 | 07:36 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
I'l take your 3.07 off your hands.
