89 side marker function????
Old May 16, 2010 | 03:53 PM
kitttransam's Avatar
kitttransam
Default 89 side marker function????
Ok on my 89 vette are the side markers (the clear section) up front supposed turn on solid when the turn signals are on when the headlights are on?? How do the side markers function normally???
Old May 16, 2010 | 07:21 PM
Hooked on Vettes's Avatar
Hooked on Vettes
GM calls the two front clear side marker lamps cornering lights.
With the ignition ON.
When the headlight switch is in Head or Park and the turn signal switch is activated for a LH or RH turn, a switch which is part of the turn signal hazard switch assembly closes.
12 volts from the headlight switch passes thru either the LH or RH cornering lamp switch and applies 12 volts to the cornering lamp bulb.
The lamp will stay on solid as long as the turn signal switch is active.
Old May 17, 2010 | 03:00 PM
kitttransam
Well I guess that means it's working like it should. At least now I know theres no electrical problems.
Old May 17, 2010 | 06:40 PM
floridamale's Avatar
floridamale
The rears will come on when in reverse under the same switch condition
To 89 side marker function????
