Tool to remove backup switch
Old May 17, 2010 | 08:42 AM
Warren Seale's Avatar
Warren Seale
Default Tool to remove backup switch
What tool is used to wrench out the back up switch on the ZF 6 spd? It looks too tight to access for standard sockets or wrenches.
Warren
Old May 17, 2010 | 10:10 AM
techvette's Avatar
techvette
Go to Harbor Freight and buy a set of offset wrenches. I forget what the exact size is for these, but a whole set is like $15. It's tight quarters in there, but that is all I needed to get the job done.
Old Jan 8, 2011 | 02:06 PM
rjrjs's Avatar
rjrjs
Warren
Removed the clutch slave cylinder, then used an oxygen sensor socket to remove the switch.
Old Jan 8, 2011 | 10:51 PM
Cyclonite's Avatar
Cyclonite
Offset wrench. Check the size you need on the new sensor, somewhere around 21mm IIRC...it's been a few years
Old Jan 9, 2011 | 01:02 AM
jfb's Avatar
jfb
I had my brother take a 7/8 socket, center on the internal flats and then machine the outside of the socket for a .015" wall to the internal hex peaks. Fits onto the switch and removes old and installs new switch perfectly!
Old Jan 10, 2011 | 12:59 PM
Warren Seale
Something like this:
http://forums.corvetteforum.com/c4-t...ht-switch.html
Old Jan 10, 2011 | 04:25 PM
mashinter's Avatar
mashinter
I found a standard Craftsman 7/8 box wrench worked for me; the wrench is an oldie, probably 1963.
Old Jan 11, 2011 | 01:22 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
I've used one of these
To Tool to remove backup switch
