Window regulator installation instructions
Old May 17, 2010 | 01:21 PM
FAUXGS's Avatar
FAUXGS
Default Window regulator installation instructions
I'm looking for the installation instructions to mount late window regulators in early C4's. If memory serves, it included where to drill mounting holes in the bottom of the door.
Thanks!
Gerald
Old May 17, 2010 | 05:47 PM
HlhnEast's Avatar
HlhnEast
Thanks!
Gerald
Leesburg, Send me yer email addy, I have a .pdf that a Forum member gave me.
BTW, I usta live in Clermont before it exploded.
Old May 17, 2010 | 06:00 PM
86PACER's Avatar
86PACER
Thanks!
Gerald
http://webpages.charter.net/khasting...windowreg.html
Old May 17, 2010 | 07:05 PM
nutz4c4's Avatar
nutz4c4
Check along the bottom of the door.The proper holes were already in my early 86. Maybe you'll get lucky also.
Old May 17, 2010 | 10:32 PM
C4boy's Avatar
C4boy
Ditto. I got lucky when I did mine too. I think the pilot holes are there in Late '86 doors.
Old May 18, 2010 | 08:21 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Thanks!
Gerald
http://members.shaw.ca/agent86/Retrofitinst.pdf
Check out 86PACER's link to Kevin's info, just ignore the part where he cuts the wires going to PS motor. Pop the terminals out of the connector, and switch them around.
Old May 26, 2010 | 01:09 PM
uedmd68's Avatar
uedmd68
When you mention 'late' what range of years should be used for the replacement motor?
Old May 26, 2010 | 01:34 PM
C4boy's Avatar
C4boy
Late model window regulators refers to 87-96 scissor style regulators. Since the regulators are all the same, I'm sure the motors must be. The early 84-86 regulators use a different design, where a nylon toothed ribbon runs through the motor.
To Window regulator installation instructions
