Low Coolant Light Question
Old May 18, 2010 | 04:10 AM
tnz5106's Avatar
tnz5106
Default Low Coolant Light Question
On my '86, every so often, the low coolant light will come on the DIC along with a chime over the radio. The coolant is fine, what causes this?
Old May 18, 2010 | 04:25 AM
86PACER's Avatar
86PACER
Air pockets still trapped in the system. '86 didn't have bleeders. You need to pack the radiator. This is done by topping it off with coolant while holding the idle at about 1500-2000 rpm after the thermostat has opened. Put the cap back on before letting the idle back down. Might have to repeat this a few times over the course of a couple of days.
I was not aware that there was a chine along with this light. Mine's never chimed.
Old May 18, 2010 | 08:25 AM
WW7's Avatar
WW7
A lot of guys drill a small 1/8" hole in there thermostat to help with getting the air out of the system,this allows the water to equalize on both sides of the stat,you still have to pack the system like 86PACER says, but you don't need to do it more then once.Next time you put in a stat you may want to consider doing this...WW
Old May 18, 2010 | 09:15 AM
kawchop's Avatar
kawchop
I had trouble packing mine until I drilled an 1/8" hole in my stat. Packed on 1st try and low coolant light has never came back on.
Old May 18, 2010 | 11:19 AM
c4cruiser's Avatar
c4cruiser
Another thing you can do is to raise the front of the car as high as possible and fill using the above procedure.
Adding some extra coolant to the overflow bottle will help too. Make sure the line from the tank to the radiator is in good condition and clamped securely.
My 87 has a chime that will go on after the Low Coolant light has been on for awhile.
Old May 18, 2010 | 11:58 AM
tnz5106's Avatar
tnz5106
Thanks guy's
Old May 18, 2010 | 02:33 PM
86PACER's Avatar
86PACER
You do it untill you can't pack it anymore. Guys who don't have a few holes drilled in the stat usually can't get fully packed the first time so it can take more than one time.
I happen to have a couple of small holes drilled in mine which helps with the process. Parking uphill or raising the front of the car to make the radiator the high point also helps since these early cars didn't come with bleeder valves.
To Low Coolant Light Question
