LT-4 stops Vapor Lock
Old May 18, 2010 | 06:26 PM
vstol's Avatar
vstol
Default LT-4 stops Vapor Lock
Well I finally go my 64GSR with a cammed Lt-4 on the road and the car has quit on me twice. First was leaving a car show where the car sat for 5 hrs, 5 minutes down the road and died. I pulled off the road waited 5 minutes and good to go, I repeated that this weekend after about 1/2 hr of driving. I have a fuel safe fuel cell with the vent as high as the filer neck and a vented cap with access to the cap for fuel on the outside of the car body ( top right side of the rear panel) and the return line hose is as big as the fuel line. Fuel pressure good with key on and running. I also thought fuel injected motors really do not get vapor locks?? Any thoughts?
Old May 18, 2010 | 07:25 PM
383vett's Avatar
383vett
You're right. Fuel injected cars with 40 psi fuel pressure do not get vapor lock. It is near impossible for fuel to vaporize within the fuel line with this amount of pressure unless the fuel line is touching a header pipe which I am sure it's not. Might be the ignition module which can go out when hot.
Old May 18, 2010 | 07:28 PM
rodj's Avatar
rodj
Do you have spark when it dies?
Old May 18, 2010 | 08:44 PM
vstol's Avatar
vstol
not sure about spark when it died I was on the side of the road so I could not chek it. I did not raise the hood so those 5 minutes the temp really did not change much
Old May 20, 2010 | 11:44 AM
vstol's Avatar
vstol
any other thoughts. It has a new MSD Opti and runs like a bat out of hell. Oly 20 k on the motor
Old May 20, 2010 | 03:24 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Vapor lock is the perculating of fuel in a fuel line due to excessive heat and the gas boils and turns to vapor. The vapor then pushes the liquid fuel back with the vapor pressure so it doesn't run. If the car isn't heat soaked, it's not vapor lock.
1. If you have a liquid fuel return line back to the tank, there should be no vapor lock.
2. I bet you have a vacuum created by the using of the fuel, and not enough fuel or air returning to the tank to balance the negative pressure.
3.I would try driving it with the gas tank cap removed or open and taped in position on the car so that it doesn't let in dirt, but vents.
It might be that the vent you have is not enough.
Old May 20, 2010 | 07:07 PM
vstol's Avatar
vstol
Thanks I will give it a try
To LT-4 stops Vapor Lock
