digital dash spedo not workind
May 18, 2010 | 11:00 PM
5th Gear
speedometer not reading mph stays at zero when driving.everything else works fine .any input would be appreciated
May 19, 2010 | 07:58 PM
May 19, 2010 | 08:17 PM
Quote:
Originally Posted by
HlhnEast
especially if "everything else" includes the cruise control. If not then I would look to the VSS and related plastic gears.
May 19, 2010 | 08:22 PM
If you have access to a scantool, you see if the VSS is working.
May 19, 2010 | 10:26 PM
94z07fx3
Had the clip that locks the drive gear onto the output shaft break on me; no speedo
May 20, 2010 | 07:58 AM
I have the same problem with my 89, how do you check with a scan tool?
Aug 26, 2012 | 11:15 PM
did you have to pull the transmission to replace the clip?
