Need Valve Job Advice
A couple things I'm concerned with is, what kind of can of worms am I going to open up considering the motor has 187K on it? And what should I look for in a machine shop to make sure they're done right. I haven't gotten any good, local recommendations yet that I felt comfortable with. I'm looking at this more from a stock/repair perspective than performance, but I'd still like to have everything done right and replace what's needed. A rough idea on cost for comparison would be appreciated as well.
Forgot to mention, it's a late '86 with aluminum heads.
Do a search on this subject and you'll get an idea of what it takes. On an L98 TPI motor, it might look easy, but it takes a good amount of elbow grease and forethought to do it right! While the ARP bolts are great for the cylinder heads, stay away from them on the intake manifold. The original torx fasteners are a 'button' style of bolt head with more clearance than a regular octagon bolt. You'll have trouble with the TPI runners interfering with the fit to the air box! Take lotsa pics and don't drop anything in the engine compartment. There are places in a C4 engine compartment that once it goes there, you'll never see that bolt/washer/nut again!
Take lotsa photos during disassembly!!! The intake manifold itself must have a dozen little parts hanging off've it that have to go back on at exactly the same angle. The air and water temp sensors are right next to each other and take the same thread, so you can't mix those up either.
Be patient removing all the stuff. You don't have to unhook the AC, it will lay off to the side complete. Ditto for the throttle cables, electrical harnesses, etc. Might as well do the injectors while you're at it and replace the fuel regulator, as it's underneath the TPI on the rear. Note carefully the routing of the vacuum lines on the TPI, as one of the hard lines runs through the inside of the TPI and exits out the passenger side.
Finally, find a Machine Shop that will hot tank all the dirty parts for you! It doesn't cost much, but man, it'll save you hours and hours of scrubbing hard-baked crap off've brackets, etc, etc. Finally don't be afraid to grind the crap off've the top of the pistons with a wire brush. Vacuum real good after you're done!
If you do it right, it will all go back together again. It's been two years since I did the 87 and it just passed California Smog last week again and still running strong.
With thos miles have the guides checked to make sure they are within spec, dont want a fresh valve job only to find the valve is moving around and beating the new surface up. Guides are cheap, they will probably want to do all of them if 1 or 2 are bad. Plus side is they last a long long time and dont really wear much. Rates will vary, have them blend the valve job into the bowl so your flow isnt hurt...some do some dont. Not doing it can hurt flow by 10-15cfm or more.
If you haven’t replaced your injectors check them before the tear down also check the FPR and the EGR .
Also you might consider 1.6 rollers
I've got shop manuals and have been reading some other threads as well, but any info is always good. The car is still driveable now, but when I do go at it, I want to get it done and not turn it into a project.
I'm not even going to touch on the "other" issues you may encounter by doing a valve job at 180,000 miles, but a leakdown test would be a good investment before doing anything
Also it took so long, because I cleaned everything under the hood or clamshell. Replaced the water pump too, as that's cheap and easy to do.
Finally, research how to adjust the hydraulic lifters on a small block chevy. The FSM has you doing it one way, but the machinist at the shop recommended doing each lifter one by one, as they sit on the base of the cam (the lowest point). You can find this on the internet.
Compression test is a good idea. If the heads/valves are good/reusable figure about ~$600 for head/valve machine work and a new spring kit with all the related goodies.
Think about what your willing to invest in an "old" set of heads before you decide between new or redo.
