Alignment specs for toe in/toe out
Old May 19, 2010 | 04:12 PM
qwiketz's Avatar
qwiketz
Default Alignment specs for toe in/toe out
where should my toe in/toe out be? I need to make some suspension adjustments after replacing my steering rack.
Old May 19, 2010 | 04:18 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
zero toe
Old May 19, 2010 | 04:20 PM
ggrassmid's Avatar
ggrassmid
It can depend on what you want. Most street cars I believe have some toe in. I changed mine to 0" both front and rear, I do some autocrossing too, and I really like it as well as other ailgment spec I did. I dont feel like it wanders in the groves on the highway as bad as it did before.
Front: 0" toe 5* caster -.75* camber 275/40/17
Rear: 0" toe -.75* camber 315/35/17
I do a fair amount of street driving, so I didnt put alot of neg. camber on either front or rear.
Old May 19, 2010 | 04:58 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Here is a good write-up on Corvette alignment specifications
File Type: doc
Old May 20, 2010 | 01:42 PM
astock165's Avatar
astock165
Zero toe in the front is a nice, nuetral setup and will not cause strange wear on the front tires.
You want some toe in on the rear for high speed stability. I usually run between 1/4" and 3/8" total toe in on the rear on my track car.
When adjusting the toe you should take the opportunity to set the thrust angle as well. That will help handling a great deal.
To Alignment specs for toe in/toe out
