Where to get hatch latch assembly?
Old Mar 18, 2002 | 03:32 PM
Kale's Avatar
Kale
Default Where to get hatch latch assembly?
Where can I get hte latch assembly for the hatch? I can hear the glass isn't being "held down tight" because of the noise on bumps and dips, and it literallly "bounces" when using hte hatch vent.
[Modified by Kale, 1:33 PM 3/18/2002]
Old Mar 18, 2002 | 03:47 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: Where to get hatch latch assembly? (Kale)
Did you try adjusting the latch on the car? it should move up and down a bit IIRC.. but I think the hatch will still shake with the hatch vent.. Mine always has Never had a trouble here in the Chicagoland area with the crappy road we have
Old Mar 18, 2002 | 03:49 PM
Kale's Avatar
Kale
Default Re: Where to get hatch latch assembly? (-=Jeff=-)
the noise with the hatch vent drives me insane. Didn't know yo ucoudl adjust it, hmn.. interesting.. ill take it apart at lunch, thanks.
Old Mar 18, 2002 | 04:03 PM
JonM's Avatar
JonM
You may want to check see if the rubber didn't slip off. (its only friction fitted) Or the sleeve may have seperated from the rubber.
Old Mar 18, 2002 | 04:15 PM
Greg Johnson's Avatar
Greg Johnson
Try Ebay.
To Where to get hatch latch assembly?
