Help prepping the deck for head installation.
Old Mar 18, 2002 | 05:17 PM
C4-Wolf's Avatar
C4-Wolf
Default Help prepping the deck for head installation.
What to use to clean the surface?
What not to use?
Any helpful advice?
Thanks again,
Jeff
Old Mar 18, 2002 | 05:22 PM
KYVette90's Avatar
KYVette90
Default Re: Help prepping the deck for head installation. (C4-Wolf)
Wipe the deck down with rubbing alcohol real good and let it dry. That will get all of the oil and dirt off.
Old Mar 18, 2002 | 05:44 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: Help prepping the deck for head installation. (KYVette90)
I used a puddy knife and then a very fine sanding block (gently) to get the mineral deposits off from around the cooling holes. actually my dad did it, he has done fine polishing of powder metal tooling were .0001" is critical, therefore I was not worried. Its cleaned them really good. I then took acetone and wiped everything very well. Just make sure when you rub your hands across the surfaces, there are no high/low spots from deposits or gaskets. It needs to be VERY clean. Good luck
Old Mar 18, 2002 | 05:51 PM
C4-Wolf's Avatar
C4-Wolf
Default Re: Help prepping the deck for head installation. (ski_dwn_it)
Thanks guys.
To Help prepping the deck for head installation.
