I forgot where this bracket goes!
Old May 21, 2010 | 09:11 PM
samsonb's Avatar
samsonb
Originally Posted by rodj
Are 3 brackets on late L98 compressor .
Long one from back to exhaust bolt.
Short one down to fuel pump block off plate stud
Your spare bracket runs from front inside of compressor bracket to top water pump bolt
Do I win a prize?
What years had that brace in the red circle? My 89 doesn't have that brace.
I know mine has that long brace going from the top of the compressor to the exhaust stud. But do you have a pic of that short brace you are talking about that is down to the fuel pump block off plate stud?
As I'd like to see if I have that brace as well.
Old May 21, 2010 | 09:54 PM
rodj's Avatar
rodj
Originally Posted by joshwilson3
But do you have a pic of the short one down to the fuel pump block off plate stud?.
Bolt goes through A/c bracket in location shown to bottom brace.
Old May 21, 2010 | 10:08 PM
rodj's Avatar
rodj
As a note ,
because of the p***weak design of the bracket and the compressor offset from the engine, GM had to add all the extra scrap metal to stiffen it up .Note the strength / size of the LT1 accessory mounting bracket
Because they are " delete" options for some people when reinstalling A/c ,many future owners have problems with A/c vibration not knowing the factory braces are missing.
I sold one guy a compressor because he thought his compressor was bad because of vibration.In talking to him ,I mentioned the braces.Sold him the two smaller braces which he fitted to his original compressor and problem went away
Old May 21, 2010 | 10:10 PM
samsonb's Avatar
samsonb
Thanks. 89 must not have that. As I went out and looked again and there is no hole there by the tensioner for a brace to bolt onto. Plus, that area that brace bolts to looks different on my 89.
Do you have a close up pic of the bottom of the AC Compressor where that center brace is bolted at? As I wonder if my 89 is even supposed to have that. Right now, there is just the end of the bolt sticking out from the threaded hole in the bracket. I'll have to get a pic of it later.
Old May 22, 2010 | 12:07 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Au contraire, Josh. My 89 also has the lower brace pictured above. Theres a stud in the upper right fuel pump cover and a hole in the A/C bracket (between the tensioner and hose cutout).
Here's a closeup pic. (Mine have now been baked with black paint).
In fact, I completely reversed colors on the pullies and brackets...
Old May 22, 2010 | 12:34 AM
rodj's Avatar
rodj
Pic is of a '89 engine I pulled.'90 engine I have on the floor at present is the same
Any closer and all you will see is the hole .Top bracket hole is in A/c mounting bracket as shown .Greg's pic show it from the inside
Old May 22, 2010 | 12:44 AM
samsonb's Avatar
samsonb
Thanks for that pic.
I will have to go out and look again and take some pics. As when I was out there, I felt around the bracket where that coolant hose goes through. And I couldn't find that bolt hole.
Old May 22, 2010 | 12:47 AM
samsonb's Avatar
samsonb
I'm gonna check it out again. I felt around there and couldn't feel a hole or see one. But I will check again.
Old May 22, 2010 | 06:07 AM
corvette95's Avatar
corvette95
i think that hole is the bottom right hole for ac compressor, there will be a longer of the for ac compressor bolts with a rounded tip on it
Old May 22, 2010 | 08:54 AM
94vettelover2's Avatar
94vettelover2
[IMG]http://i47.photobucket.com/albums/f152/greggpenn/P1040625.jpg[/IMG
[/QUOTE]
Nice looking job/engine
Old May 22, 2010 | 10:12 AM
Aardwolf's Avatar
Aardwolf
On my '88 that fuel pump stud was used to hold the fuel lines, not a bracket. Just a reference for years!
Old May 22, 2010 | 07:27 PM
samsonb's Avatar
samsonb
I checked my 89 out again. And there definitely isn't a hole there for that brace:
Heres a pic of that block on mine:
And I wonder if mine is even supposed to have that center brace? As the top water pump stud looks rather short. Not sure if there would even be enough there to put the nut on if I was to get that brace?
Old May 22, 2010 | 10:32 PM
  #33
rodj's Avatar
rodj
'88 have the Denso or Harrison compressor?
I don't recall any extra brackets with the Harrison unit used on the early years
Maybe we need to compile a list of what years had what brackets from "original , unmolested" cars?
Old May 22, 2010 | 10:35 PM
  #34
rodj's Avatar
rodj
Who knows ,what is your build date ?
Maybe the brackets were a production change to solve the vibration problems I mentioned above
When GM had problems they weren't about to design a new bracket so they the added the braces
Old May 23, 2010 | 01:17 AM
  #35
samsonb's Avatar
samsonb
I'll have to look up my build date. How thick is the brace at the end where it gets bolted down at the water pump? I'm wondering if there is enough thread on the stud for me to put on that brace.
88 is the year they started putting in the Nippodenso compressors.
Old May 23, 2010 | 04:33 AM
  #36
vette079's Avatar
vette079
Would this http://www.compnine.com/vid.php help?
Old May 23, 2010 | 11:12 AM
  #37
GREGGPENN's Avatar
GREGGPENN
Based on your pics, it looks like you'd have to pull your waterpump. (At least I don't see enough stud to double-nut and extract it as-is.) If/when you get that stud out, you could install a longer one, drill the hole in your A/C bracket, install a longer stud at the top right of your fuel pump cover and you'd be ready to go.
If you could get that wpump stud out (w/o removing it), the mod seems like it would be fairly easy. (Assuming you can get your A/C bracket marked for a hole easily enough.)
Old May 23, 2010 | 02:46 PM
  #38
samsonb's Avatar
samsonb
Yeah, I figured there wasn't enough stud left. I'm not gonna worry about it. Not really worth it tearing it apart to get that brace to work if it never was there from the factory.
