? for Canton oil pan users
Old May 21, 2010 | 04:44 AM
Sliding's Avatar
Sliding
Default ? for Canton oil pan users
I've recently bought road racing oil pan for my Corvette.
It is part nr. 15-240T. However, I have one problem.
Pan came without one of the plugs (please
look at the picture). Does anybody know what size thread is
in that hole?
Old May 21, 2010 | 07:46 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
It's been too long since I put mine on but I think it was 1/2 inch pipe thread.
Old May 21, 2010 | 08:54 AM
Aardwolf's Avatar
Aardwolf
Same here!
Old May 21, 2010 | 09:20 AM
PDQUIK95's Avatar
PDQUIK95
From: Portsmouth Virginia 396LT4 435RWHP/400RWTQ Best so far 11.26 @ 123mph
It's 20mm used for the factory oil level sender unless you chose to delete the sender and plug it.
Rick
Old May 21, 2010 | 09:42 AM
Sliding's Avatar
Sliding
It's larger than 1/2". It could be 20mm, but it's strange that it's metric size. I'll buy 20mm plug and try with that.
Was oil level sensor optional, or only on later years, because mine never had it?
Old May 21, 2010 | 09:43 AM
Aardwolf's Avatar
Aardwolf
http://www.cantonracingproducts.com/...on&key=15-240T
The Pan Features:
* Five Trap Door Baffles
* Crank Scraper
* Built In Screen Windage Tray
* 1/2" NPT Temperature Bung
* Provision For Our Pan Mounted Dipstick
* Magnetic Drain Plug
* Includes a 20MM fitting For A Low Oil
Warning Sender (Purchase 22-405 Plug if
not using sender)
Available
Old May 21, 2010 | 10:31 AM
383vett's Avatar
383vett
Nice answer!
Old May 21, 2010 | 12:00 PM
Sliding's Avatar
Sliding
The Pan Features:
* Crank Scraper
not using sender)
Available
Thank you! I've just bought 20mm plug and it fits. You never know
with US cars, some threads are metric and some imperial
Lucky for me it's metric, otherwise I would have to order it or have it
custom made!
Thanks again!
BTW, I've also sent an email to "Canton racing products" when I posted
this, and they also anwsered promptly.
To ? for Canton oil pan users
