cd replacement
Old Mar 18, 2002 | 06:04 PM
vent69's Avatar
vent69
Default cd replacement
i have 94 and the cd player will not play,should i get a new cd player, [i really like the stock look] or should i get a cd changer??and will a changer hook up right :bb :bb :bb :bb
Old Mar 18, 2002 | 06:29 PM
kkonen's Avatar
kkonen
Default Re: cd replacement (vent69)
You can add a changer through the FM signal without a problem, although you will need a GM antenna adapter. You could get a replacement factory unit if you want to remain stock.
I just installed a Kenwood in my 95. It was easy although I did have to cut the dash. I used a wiring conversion harness so I could keep the stock Bose speakers. The total install took me about 2 hours, but I need to work on the dash opening more. I I spliced the kenwood harness to the wires to the GM convertor inside.
