A/C blower speed problem
Old May 21, 2010 | 02:54 PM
Don in VT's Avatar
Don in VT
Default A/C blower speed problem
Hi All,
On my 87, My A/C blower motor has stopped working. When I left work at 1:00 today I turned on the A/C and it seemed normal. I soon noticed that the blower motor was not running a full speed even though the setting on the electronic control was set at 10. As I drove home the motor got slower and slower until it finally stopped. The system is tight and blows very cold. It is not iced up. Sound like a blower speed control module ? Any suggestions would be appreciated.
Don in warm VT
Old May 21, 2010 | 03:21 PM
nutz4c4's Avatar
nutz4c4
Have you applied 12 volts directly to the blower motor? If it runs at high speed with battery voltage applied directly it is more than likely the module on the heater box.
Old May 21, 2010 | 05:32 PM
Don in VT's Avatar
Don in VT
Default blower motor issue
Hi,
Thanks for the reply. Do you know the color code of the motor wire and which connector it is in, big conn or little conn. ?
Thanks,
Don
Old May 21, 2010 | 06:45 PM
SunCr's Avatar
SunCr
Hot at the Blower is either Red/Black or Purple and it will be the same at the Blower Module. Just jumper the Motor directly to Battery and see what it does.
These connectors are crimped and when they get loose, there will be a voltage drop between the Motor and the Connector. That heats up the Connector and eventually it will melt, so look there first. If there's discoloration, take apart the weatherpak and solder the terminals to the wires. Motors can suck 25 amps so you want the best connection possible.
Dash input at the Module is on the Dark Brown wire and it ranges from 4volts (1 at the Controls) to 6 volts (Blower 10). Output on the Module hot side - Black/red or Purple - is 6 to 12 volts. Input but no output is a dead module.
Old May 21, 2010 | 07:45 PM
Don in VT's Avatar
Don in VT
Default AC blower issue
Hi SunCr,
Thanks for the help. It appears to be the blower motor and with 180K miles on a climate air car it seems about right for a failure. Now to find a blower motor for the electronic A/C system. Seems to be several for the manual A/C on ebay. If you know of any supplier for what I need please let me know. Again, Thank You very much for the help.]\
Don
To A/C blower speed problem
