more air
Old May 21, 2010 | 08:07 PM
mudslide's Avatar
mudslide
Default more air
I just went to install a new k&n filter in my 1990 vette. I took out the air cleaner box and down on the bottom is a plastic cover that stops the air from coming in from the bottom. should I throw it out and let the carb breath through the new hole in the bottom that the removed plastic piece has opened up???? I know it not a carb but you get the drift.
Old May 21, 2010 | 08:09 PM
Aardwolf's Avatar
Aardwolf
I tossed that on mine and haven't had any trouble.
Old May 21, 2010 | 08:15 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Isn't that supposed to keep trash out?
Old May 21, 2010 | 08:31 PM
pologreen1's Avatar
pologreen1
I think most remove it. as long as there is a filter you are fine.
Old May 22, 2010 | 10:08 AM
mudslide's Avatar
mudslide
ok guys out it goes the air cleaner will stop the debrie.
Old May 24, 2010 | 04:48 PM
j-wireman's Avatar
j-wireman
That thin, black plastic thing keeps water from being sucked into your air filter, if you drive in the rain. DON'T THROW IT AWAY. It came with the car and should go with it when you sell it.
As for your K&N filter, buy a used filter cover and cut the louvers out. Use that one on the car and keep the ORIGINAL. I used a 4" grinder with a cut-off wheel on mine. File the edges real smooth with a fine file. The cover is made of aluminum, so take your time and do a good job. My cuts were nice and straight and look like it was punched by a press. Afterward, I cleaned, sanded, primed, and painted it semi-gloss black. Turned out real nice. Looks like the General made it himself.
Mike
'90 'vert
To more air
