ZF6 fluid
Old May 24, 2010 | 03:34 PM
Cyclonite's Avatar
Cyclonite
Default ZF6 fluid
ZF6 fluid change.
1992 FSM states the fluid "never" needs changing. C'mon, really? FSM also states capacity is 32Oz. Why did the dealer say 3 quarts? Anybody know which is right?
Old May 24, 2010 | 04:59 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I have changed mine once in the 5 years I have owned it, and I will do it again after x amount of track miles.
You have to buy 3 quarts because the capacity is 2.2 quarts. You will not put all 3 in.
Old May 24, 2010 | 05:30 PM
Cyclonite's Avatar
Cyclonite
Thanks, I bought the 92 to make it atrack car and have no idea when the last PM has been done do I'm trying to get all the usual suspects checked/replaced. I thought it odd the manual says it never needs changed, and then the capacity is only 32Oz (1 qt). 1qt seemed way too low, and if 2.2 is the number, then I guess it's off by more than half!
Also, neither my 91 nor 92 manuals give capacities for the rear diff. They do say something about 12 Oz of posi additive, but the bottle from the dealer was only 4oz. Go figure.
Old May 24, 2010 | 05:35 PM
Kubs's Avatar
Kubs
The diff takes 1.8 quarts. I use Amsoil severe gear oil on the diff and it has a posi additive in it already. I also use their syncromesh in the tranny. Amsoil products are made to handle the high temps of the track and have worked great for me the last 2 years I have had it in. I also got an extra 2MPG on the highway.
Old May 24, 2010 | 07:10 PM
Vette73's Avatar
Vette73
LS/MFT
St. Jude Donor '09-'10-'11-'12
... FSM also states capacity is 32Oz. Why did the dealer say 3 quarts?...
Because he can't do math in his head.
Old May 24, 2010 | 08:18 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
More likely because that's what he has to order from the parts department to perform the service.
Also, ZF's official recommendation is 30k between changes
Old May 24, 2010 | 08:36 PM
Cyclonite's Avatar
Cyclonite
30K...interesting, seeing what the FSM for the car itself says. It's getting changed anyway, and I'm glad I bought enough for doing both cars.
Old May 24, 2010 | 08:45 PM
c4zf6nut's Avatar
c4zf6nut
Good for you that Amsoil is working in the differential and synchromesh in the transmission.
I remember, something like, synthetic fluid is NOT ecommended by GM for the differential of these cars. I would rather use a dino like Pennzoil 80W90, or a semisynthetic like Walmart's Supertech 80W90. The price per quart is like $4-5. I think Penzzoil has slip additive for the clutch pack. If you buy Supertech, just buy the 4oz (not 7oz) LS additive.
ZFDoc has a good website for these transmissions. According to maker, ZF, a German company who was contracted for the transmissions, the proper fluid is Castrol TWS 10W60, which is what I am using. The transmission fluid life is about 12K max with this fluid according to ZF Doc.
C4ZF6nut
Old May 24, 2010 | 10:49 PM
Kubs's Avatar
Kubs
C4ZF6nut
I have not had any issues with the synthetic in the diff. It has the factory seals and even with 110K miles it doesnt leak a drop, and no whine from the gears. Amsoil is good stuff and the ZF shifts smoother than the castrol (recommended) or redline (also popular) oil at street speeds or high track temps. Best investment I ever did.
Old May 24, 2010 | 10:54 PM
GREGGPENN's Avatar
GREGGPENN
That was one of two fluids recommended by ZF 15-20 years ago. ZF no longer supports these units. They've LONG ceased testing for compliant lubricants. Alot has happened in 20yrs, so don't assume this is the only fluid that will work (and work well).
The other fluid originally recommended has been discontinued by GM. I'd avoid the superceeding fluid since I'm 99% sure it existed before the discontinuation. If it wasn't their 1st choice before, how could it be the best choice now?
I personally think the Castrol stuff is too heavyweight unless you're racing or live in a very hot climate. Redline also recommends a lighter lube (of their internal choices) for that transmission. That helps to reinforce my own personal observation. MTL is Redline's recommended lube. Amsoil has also been well-received.
Old May 24, 2010 | 11:38 PM
c4zf6nut's Avatar
c4zf6nut
10W60 is not really a heavy oil, 60 weight equivalent at 100C/212F is only about 30% viscosity of 10W at 0C/32F. Part of the appeal of this viscosity is that it is not a mainline lubricant so it does not have to be energy saving type, with various compromises making it unsuitable.
MTL/MT90 were around 15 years ago, and ZF not supporting it tells me that it is not suitable. Those are manual transmission gear oils with GL-4 rating.
Some transmissions use engine oil for a reason, like Honda, Saab etc. I would rather use Honda MTL fluid which superceded 10W40 SG rated oil recommendation than Redline MTL which is a GL-4 rated gear oil.
Gm synchromesh or Pennzoil Synchromesh has been proposed. I may try the latter sometime, but I am happy with Castrol 10W60.
C4ZF6nut
Old May 25, 2010 | 08:37 AM
jmgtp's Avatar
jmgtp
I'm running the Pennzoil branded scynchromesh - it was the only thing locally available off the shelf. No complaints. 3rd gear sometimes feels like it takes a bit more effort to shift into but it was like that before the new fluid. Might try Amsoil some day to see if it can remedy that issue.
To ZF6 fluid
