Resonance, where does it come from?
Old May 26, 2010 | 03:20 AM
samsonb's Avatar
samsonb
Originally Posted by JrRifleCoach
Again, the fix has been to block one of the outlets.
Quote from CC's website: Corvette Central is pleased to introduce our exclusive correct sounding dual outlet mufflers for the 1984-1990 Corvette. These are manufactured and welded in USA by Corvette Central (cases are manufactured in Canada).
On the original 1984-1990 dual-outlet muffler, the inner outlet tube is for appearance only, and is blocked off. With our design, the outer outlet tube is open, but the inner outlet tube is connected to a small diameter resonance tube. This design provides the correct sound and quietness of the original design without the annoying low-RPM drone.
I'm sure there are single outlet mufflers that have drone. My OEM mufflers had drone and they are single outlet. So, I don't think having single outlet alone gets rid of drone.
What Corvette Central did was put a resonance tube in one of the outlets. I'm assuming it still passes exhaust out that tube. So, I don't think they 100% blocked it off. This is the first I've heard of having a resonator in the muffler.
But I had put in some Walker mufflers a while back. And that got rid of the drone. I think they were the Quiet Flow.
Old May 26, 2010 | 10:20 AM
vader86's Avatar
vader86
Resonance is a characteristic of all exhaust systems where the engine RPM matches the resonant frequency of the exhaust system. All of them will resonate at different frequencies, yet some are not going to resonate at frequencies your engine can create or will resonate to varying degrees. Some may be so quiet so as to not be annoying. Sometimes thats because theres something inside to break up those pressure waves, which is what a resonator does. X and H-pipes do the same thing.
It depends on full exhaust length, diameter of the pipe, the flow ability at choke points like Y-pipes, etc. In general, shortening the exhaust piping raises the RPM with which resonance occurs at, lengthing lowers the RPM. If your engine never constantly runs at that RPM, then you've gotten around the problem. I believe thats how the Corsas do their magic.
Old May 26, 2010 | 10:55 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Originally Posted by cshuman
What do you guys think about putting one of the dynamax or magnaflow mufflers with two pipes in and out in the center where the resonator would normally go and then just run straight pipes to the rear, past the bumper cover? Do think this would help? Most of the muscle cars I've seen that have the mufflers in the center of the car don't have resonance.
After re-reading the dialog between cusinartvette and coupeguy, they both are leading up to what the OP is thinking. Center mounting a dual in/out muff and extending the outlet tubes seems a likely design. Not much room under there without removing the spare.
Old May 26, 2010 | 04:08 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
It's always helpful to have a physics major in the car-pool
Old May 26, 2010 | 04:16 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
I have the rear y with crossover and I don't notice much res., if any at all. magnaflows
Old May 26, 2010 | 05:38 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Originally Posted by coupeguy2001
I believe if you can get an H pipe in there, it would be a change, but it would be for the better. The colliding of the exhaust pulses is probably where most of the resonance is coming from. Actually, removing the X pipe, and making them true duals would be the best thing for resonance
I screwed around w/the the exhaust system on my C6 in an effort to improve the QUALITY and CHARACTER of the exhaust sound...which sucks on the C6. I used 4 different "mufflers", and I fabed up three mid pipes (where the "H" pipe is stock). None of that made any difference w/regard to "resonance" (or with my original goal).
You can read the whole thread HERE, and the actual posts HERE, here, here and the summary, HERE. For a chuckle, read the exciting conclusion, HERE.
Also, I don't believe about the muff's being close to the end of the exhaust; Mustangs, GTO's and CTS-V's (among others) have muff's right at the end of the system, and don't resonate as badly (as the C6 does at least).
I agree w/the guy that talked about the rear cargo floor. I've READ (but not tried) that putting dynomat on that area reduces drone enormously.
Old May 26, 2010 | 06:23 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
I introduced some irritating resonance in my 1989 when I eliminated the pre cats and went to dual outlet OEM style Magnaflows. It is only annoying between around 1200 and 1500 rpms and with a 6 speed I'm not in that range very much. I think it is caused by the dual outlet mufflers setting up a vibration.
Old May 26, 2010 | 06:52 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
I like the explanation above best. It's very similar to the issue of how ported speaker cabinets work.
I would add to Vader's explanation that the cabin shape probably adds to the engine rpm/exhaust length tuning effect. Because the rear of the couple is shaped like a cone (at least part of one, I suspect sound is "focused" back toward the seating area. Though I don't want to consider/compare it to a parabola, anything close to that shape could have a tendency for focusing sound.
My experience was similar to BADDUCK's. The removal of front cats, installation of 2.5" front "Y", and dual-outlet resonators caused a pronounced resonance at lower rpms. All I had to do was reinstall front cats (Magnaflow spun cats in my case) and the sound went from annoying to music.
Old May 26, 2010 | 10:14 PM
Klondike's Avatar
Klondike
Just a thought
I thought of that very same thing and was ready to do it. BECAUSE; Mustangs have the mufflers up under the car and a long tail pipe out the back and they sound GREAT! Maybe that's the difference between having long pipes to the mufflers in back and a short exit pipe like Vettes or like the Mustangs have the mufflers close to the front with long tubes to the back exit.
Sadly the Dynomax dual in & out muffler is just a bit too fat to fit under the Vette like the original resonator does. Maybe some sharp muffler guy will fab up one similar that will fit under there and then use the 'muffler eliminator' pipes out the back. Then we'll know if that's the answer to the deafening resonant drone v/s good tone.
Old May 26, 2010 | 10:25 PM
cshuman's Avatar
cshuman
My original post of putting the single muffler in the location of the resonator then running pipes to exit at the original location would keep the noise from the muffler closer to the seat area, thus keeping it out of the coupe area. This I believe would help eliminate the resonance.
My current set up has Hookers to the magnaflow dual in dual out located at the resonator area out to two magnaflow mufflers at the original locations and I still have resonance at the 1100 to 1400 RPM range.
Do you guys think, based on the responses above, that my original suggestion may work?
Old May 26, 2010 | 10:28 PM
ch@0s's Avatar
ch@0s
I think you might be onto something try it and see.
Old May 26, 2010 | 10:45 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Not since '05 or so...
Old May 26, 2010 | 10:49 PM
  #33
neat's Avatar
neat
I plugged one of the tips on my magnaflows long ago with steel wool. It helped some, but the resonance is still pretty bad.
Old May 26, 2010 | 11:38 PM
  #34
ch@0s's Avatar
ch@0s
A friend has a set on his ZR1. Only one tip works.
So I experimented with my Borlas and blocked one tip.
Resonance was reduced significantly.
From what I have read from previous posts the corsa are not fully functional the outer tip is still there for a reason to release internal pressure from the cancellation chamber therefore canceling the resonance.
Old May 27, 2010 | 12:11 AM
  #35
GREGGPENN's Avatar
GREGGPENN
I don't. There have also been threads suggesting that a single element (like a cat or muffler) causes resonance.
If that dual-in/dual-out piece in your mid-section is a muffer or resonator, using it with straight pipes to the back will only make it louder. Resonance may change it's focal point though.
My first thought would be to put dual glass packs in the belly, leaving your Magnaflows at the rear. IOW, create a true dual config. (That solves the "Y" interaction spoke about in this thread. (The longer the glass pack, the quieter the result.)
Old May 27, 2010 | 12:34 AM
  #36
jakers's Avatar
jakers
St. Jude Donor '06
"Resonance, where does it come from?"
My theory is this... C4 exhaust resonance comes from Hell!!!! First Generation B&B (Billy Boat) exhaust systems are the spawn of Satan. Couple the B&B with Long tube headers and a LT-4 Hotcam and drive for more than 45 minutes and your head will feel like Satan : and all the members of AC/DC have moved into it. Ask me how I know!
My car still has the long tube headers and the Hotcam but no B&B. I switched it out for a factory exhaust and it purrrs at cruise and roars when I get on it...
Before you spend alot of money experimenting, aka spending tons of money, go back and search for old write ups here on the forum. You will learn alot and it will prevent you from repeating mistakes that others have made. Good luck!
Old May 27, 2010 | 09:03 AM
  #37
CorvetteCentral.com's Avatar
CorvetteCentral.com
Platinum Supporting Vendor
Josh -
According to our designer, yes, that small tube in our new C4 muffler does enable some (minimal) flow between the muffler’s front (inlet) chamber and the second outlet. The small diameter tube is designed to function as a pressure relief/vent and reduces peak internal (muffler) pressure. That is probably a contributor to the reduced levels of drone that these mufflers provide.
The primary reason the mufflers sound “right” is that our new C4 muffler is identical in design and function to the original C4 muffler, including the tube diameters, chamber lengths and chamber volumes. The resonator function is built into the internal design of the muffler. A reverse flow pattern in the front section of the muffler is combined with a rear chamber that functions as an expansion chamber/resonator.
To Resonance, where does it come from?
Old May 27, 2010 | 09:21 AM
  #38
vader86's Avatar
vader86
Originally Posted by GREGGPENN
I would add to Vader's explanation that the cabin shape probably adds to the engine rpm/exhaust length tuning effect. Because the rear of the coupe is shaped like a cone (at least part of one, I suspect sound is "focused" back toward the seating area. Though I don't want to consider/compare it to a parabola, anything close to that shape could have a tendency for focusing sound.
It does add to it, put the same exhaust on a convertible and the resonance will be less.
Old May 27, 2010 | 11:27 AM
  #39
lt4obsesses's Avatar
lt4obsesses
Just a thought
This is the exact system I am running. I am using the Magnaflow dual in dual out, as I tried the Dynamax, but it was too wide to install. I personally really like the sound. Magnaflow puts a high flow x-pipe along with sound damping material in this muffler, which really helps to give a nice tone. Yes, it can be loud, but hearing your engine is not what I consider resonance. The trick is to make sure the tips are about 1/2" beyond the bumper and point slightly downward. This keeps the bulk of the sound from the cabin.
  #40
dogfish246's Avatar
dogfish246
Does anyone have any pics of an LT1/4 muffler cut open like the corsa muffler? I would love to see the difference? How about the center resonator?
Maybe if we get as many pics of mufflers cut open and peoples experiences we can see what could possibly work...
I think the Vettes shape, the material it uses (fiberglass), the engine tune/gears, and the location of the exhaust have to also do a lot with the resonance. Maybe if the pipes were separated they wouldnt act as tuning forks. I am not sure, just throwing some ideas out there.
Exhaust flow has a lot to do with it because when you add restriction it usually cuts down the resonance. Like stated above its probably caused by sound waves cancelling but if that is so then how do you make a free flowing muffler that is low on resonance?
