92 instrument cluster problems
Old May 26, 2010 | 06:00 PM
bigblazer1891's Avatar
bigblazer1891
Cruising
Default 92 instrument cluster problems
my 92 vette instrument cluster is acting strange. sometimes it will be just fina and others it will be a bunch of flashing jibberish on the screen. If i hit the top of the dash while this happens, it USUALLY will stop for a bit. sometimes it just goes blank, but stays lit, so i hit it again and it is ok. Any Ideas?
Old May 26, 2010 | 07:53 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
check grounds and loose connections. Probably means you need to pull it out
Old May 26, 2010 | 10:05 PM
bigblazer1891
Cruising
Anyone know where all of these connections are???
To 92 instrument cluster problems
