Door Panel Fix...L Bracket
Old May 27, 2010 | 04:36 PM
VA50th's Avatar
VA50th
Default Door Panel Fix...L Bracket
...for those you did the door panel fix using the L bracket, where did you get your brackets?? I've been to Lowes, Home Depot, Northern Tools, Ace and True Value. Most have a L bracket (one inch) but the hole is too small. From reading the forum posts and looking at the pic from the Corvette Fever article, it looks like you need a bracket that will take a 10mm bolt or screw. help!
Old May 27, 2010 | 06:06 PM
joesgulfstream's Avatar
joesgulfstream
Just drill the whole to the size you want
Old May 27, 2010 | 07:02 PM
VA50th's Avatar
VA50th
...yup...that might be what I end up doing. The brackets I did find were one inch high X 1/2 inch wide. Everthing I've read not to exceed one inch. Does that sound right.
I wonder (don't laugh) if it's possible to use JB Weld on the bracket to the door? Just a thought!
Leave it to me to make a 'simple' process a major event.
Old May 27, 2010 | 08:06 PM
ch@0s's Avatar
ch@0s
Old May 28, 2010 | 07:03 AM
joesgulfstream
I don't think I would use JB Weld. If all else fails resort to the screw trick,thats what I did
To Door Panel Fix...L Bracket
