No voltage to a/c compressor
Old May 31, 2010 | 09:21 AM
twin540's Avatar
twin540
Default No voltage to a/c compressor
I'm not getting any voltage to my low pressure switch .Where should I start?? My fuse is good ,does anybody have a schematic for a 91 ? thanks..
Old May 31, 2010 | 11:48 AM
gbrtng's Avatar
gbrtng
Your subject line and text do not agree - what's the real problem? Let's start there.
Old May 31, 2010 | 04:44 PM
RWDsmoke's Avatar
RWDsmoke
Is it manual or electronic climate control? Manual a/c switching is done on the power side but climate control all switching including pressure switches is in the ground circuit.
Old May 31, 2010 | 07:01 PM
ch@0s's Avatar
ch@0s
Old May 31, 2010 | 07:21 PM
kittmaster's Avatar
kittmaster
Are you sure you have any freon in there? The low pressure switch may be protecting the system if there is not enough freon to run it.
Old Jun 2, 2010 | 09:59 PM
twin540's Avatar
twin540
Sorry it took a while, back from vacation. Yes I do have refrigerant , I bypass power to one side of pressure switch and it kicks on with 55 psig pressure at idle . Low pressure switch shows continuity, i just don't show any voltage going to switch.
Old Jun 2, 2010 | 10:05 PM
twin540's Avatar
twin540
Electronic climate control.
Old Jun 3, 2010 | 08:36 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
As RWDsmoke has mentioned, there is no power going to the pressure switches, they complete a ground circuit that goes back to ECM.
I can't 100% confirm this on your 91, as my info is from my C68 in my 86.
Maybe my info will shed some light, though.
http://members.shaw.ca/dankai/HVAC%20Electrical.pdf
Old Jun 3, 2010 | 01:45 PM
SunCr's Avatar
SunCr
Sounds like no gas - or too much gas - to me, though it would help to know the outside air temp. Contacts close at 50 psi, but static pressure should be in the '80's - assuming it's 70 or better - and once the clutch engages, the low side should be 28 to 38. If you've got 55 at idle with the clutch engaged, check the high side. If there's 55 static, check your low again as my guess is that it's dropping well below 25 psi which opens the contacts. If they're opening and closing rapidly - which they do when there's not enough gas - the ECM shuts down the compressor relay and your Panel will have a trouble code. Your '91 also uses a pressure sensor for fan control and as a high pressure cutout. If you have a scanner, you can see what it's showing or hookup a manifold gage set. Anyway, either condition - low or too much gas - shuts it down and it's going to stay shutdown until you fix it and clear the Code which you can do by disconnecting and then reconnecting the battery. You might just try that first and see what happens.
Old Jun 3, 2010 | 01:50 PM
94z07fx3's Avatar
94z07fx3
Look at this post. http://forums.corvetteforum.com/1570426699-post29.html
See if the ECC will tell you what's wrong.
Old Jun 6, 2010 | 03:21 PM
twin540's Avatar
twin540
Found bad low pressure switch.. Thanks ..What I had problems was I was getting continuity at low pressure switch.
To No voltage to a/c compressor
