1990 idle issue
Old May 31, 2010 | 02:47 PM
bonric60's Avatar
bonric60
Default 1990 idle issue
I have a 90 Vette with 92k original miles. Out of the blue it started giving me idle issues once it warms up. I checked spark plugs, sparkplug cables, vaccume lines, ignition and injectors and yet no joy. Anybody know of what else to check. It idles great until it warms up.
Old May 31, 2010 | 08:21 PM
EastCoastHD's Avatar
EastCoastHD
Sounds like a problem after your car goes into closed loop, possibly.
The easiest way to diagnose driveability issues is with the use of a datalogging program. That way you can observe / monitor certain sensors under operating conditions.
Did you ohm your injectors hot & cold?
O2 sensor been replaced?
Fuel pressure?
Old May 31, 2010 | 08:55 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Can you describe your "idle issues" a little more in detail. What exactly does it do? What does it sound like compared to a normal idle?
Old May 31, 2010 | 09:10 PM
esham's Avatar
esham
Old May 31, 2010 | 10:20 PM
Jamesnns's Avatar
Jamesnns
In front of your TB, there's a little hole in the middle on the bottom. VERY easy to get too.
With car running, spray some carb cleaner in the little hole, rev engine, repeat 4-5 times.
Your engine will bog down while doing this, no problem
You're cleaning your IAC.
If this impproves your idle, replace your IAC, or keep it clean.
Old Jun 1, 2010 | 07:24 PM
bonric60's Avatar
bonric60
while cold it idles very smooth as soon as it heats up the engine starts to shake like if it was some elcetrical problem or like when you have a carburated car and you have more air than fuel. Just not idling good
Old Jun 1, 2010 | 07:29 PM
bonric60's Avatar
bonric60
How do I go about ohms my injector and what would be the tolarence I'm should be looking for?
Old Jun 1, 2010 | 07:47 PM
esham's Avatar
esham
http://www.youtube.com/watch?v=_g8Pd...layer_embedded
To 1990 idle issue
