Air Pump Eliminator
Old May 31, 2010 | 08:58 PM
vette40509's Avatar
vette40509
Default Air Pump Eliminator
Can anyone send me some pictures to malcolmmar@msn.com of your installed air pump eliminator kit. I bought one a couple of years ago but lost the instructions and am almost ready to start a new engine. Thanks to all who reply!
Old May 31, 2010 | 09:20 PM
rodj's Avatar
rodj
Simple enough
Bracket bolts to head with the two supplied spacers and arm goes to Alt
Somebody else's install.
Old May 31, 2010 | 09:22 PM
vette40509's Avatar
vette40509
Thanks, but I must have a different kit. My pieces don't quite look the same. Thanks!
Old May 31, 2010 | 09:40 PM
383vett's Avatar
383vett
Bad picture, but does this look more like yours?
Old May 31, 2010 | 10:07 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Did you ever consider that posting pics of YOUR setup and asking for help would be easier/better than asking LOTs of people to post/send theirs?
Old May 31, 2010 | 10:58 PM
korvette4u's Avatar
korvette4u
or like this ONE...look at the avitar
Old Jun 1, 2010 | 01:04 AM
rodj's Avatar
rodj
This one maybe ?
Old Jun 1, 2010 | 01:55 AM
Aardwolf's Avatar
Aardwolf
Eh, sell it it someone and don't use one:
Why do you want a useless POS stealing your money and space?
Old Jun 1, 2010 | 03:25 AM
lil_Mike's Avatar
lil_Mike
do you have a pic of the other side where the a/c is?
Old Jun 1, 2010 | 04:42 AM
rodj's Avatar
rodj
You mean where the A/c used to be ?
No air pump eliminator needed with A/c delete
Old Jun 1, 2010 | 05:10 AM
Sliding's Avatar
Sliding
What kind (manufacturer) water pump do you have?
Old Jun 1, 2010 | 10:55 AM
Aardwolf's Avatar
Aardwolf
I had a reverse rotation Edlebrock (Corvette specific) on there and it was fine turning it normal rotation.
Now in that picture is a Weiand twisted snout type that I got in the for sale section. It's normal rotation and not a 3/4" shaft, I think it's 5/8". I had to get a bushing for it to fit the Corvette pulley. Anyways it didn't cost much but the 1 7/8" water outlet is a pain. I had to make a radiator hose adapter out of smaller hose for it. I should get rid of that brass plug on top too. Oh and it needed to be clearanced by the alternator bracket.
Old Jun 1, 2010 | 11:29 AM
Sliding's Avatar
Sliding
Thanks!
Old Jun 1, 2010 | 12:35 PM
Bondami's Avatar
Bondami
From: Southside of Western Norte Americano State of Confusion, ColoFornia
St. Jude '13
I would love to ditch the A/C and the smog pump.. I dont use either one for anything but the belt .What belt are you using Rodj ?? and thats the normal vette waterpump on there? It looks like you also removed the tensioner pulley?
Old Jun 1, 2010 | 05:25 PM
Calderone's Avatar
Calderone
wow no tensioner pulley ??? !!!
i already have a Corvette water pump as well...what if it rotates in the other way ?
Old Jun 1, 2010 | 06:31 PM
Aardwolf's Avatar
Aardwolf
I addressed that above. I ran it for a year doing street driving and track events, both road racing and drag racing, with no heat issues. I then found a deal on a normal rotation pump and sold mine for more then this other one cost, so I switched.
Old Jun 1, 2010 | 07:52 PM
vette40509's Avatar
vette40509
OK, how do I post picture of parts I have, If I remember I bought it from someone on the forum that makes them.
To Air Pump Eliminator
Old Jun 1, 2010 | 07:57 PM
383vett's Avatar
383vett
An 82 Corvette water pump is not meant for reverse rotation and the vanes are pointed the right way. It's a bolt-in replacement.
Old Jun 1, 2010 | 08:22 PM
383vett's Avatar
383vett
Here's a picture of an air pump delete modified with an idler instead of a pulley in conjuction with the air conditioner delete pulley. I still use the tensioner and have a Meziere water pump to eliminate the mechanical pump.
Old Jun 1, 2010 | 09:23 PM
rodj's Avatar
rodj
All here Post # 48 on
http://forums.corvetteforum.com/c4-t...-pulley-3.html
The adjustable brace to the Alt becomes your belt tensioner
I made one out of bar , Aardwolf used the old rear compressor brace and Mseven bought a fancy one
Using the stock pulleys I have a 1425mm belt
Gates # 6PK1425
You need to set it up then measure for belt as length will vary according to how/where you mount your alt.
l
