rear leaf spring broke
Old Jun 1, 2010 | 12:06 PM
gixxr's Avatar
gixxr
Default rear leaf spring broke
hi guys my rear leaf spring broke, were can i get a good new one? any ideas would help.
93, FE1, 6 sp,
Old Jun 1, 2010 | 12:23 PM
Bondami's Avatar
Bondami
From: Southside of Western Norte Americano State of Confusion, ColoFornia
St. Jude '13
I found the best deal at vette brakes and products (VB&P) they shipped it right away and its a quality piece.
http://www.vbandp.com/detail.aspx?ID=379
It took about 20 minutes to install..
Old Jun 1, 2010 | 12:43 PM
gixxr's Avatar
gixxr
thanks, ill check them out, also any idea on labor charge for that job, right now its sitting at a shop that seems to be competent however i do not like to be over charged, they quoted me just under 300, if it only takes 20 min it sounds like it sould be less
Old Jun 1, 2010 | 12:52 PM
pmihaltian's Avatar
pmihaltian
Slingshot
$300 would be a good price if it includes the part.
Old Jun 1, 2010 | 12:54 PM
gixxr's Avatar
gixxr
no just labor, im getting the spring and hardware
Old Jun 1, 2010 | 01:03 PM
MK 82's Avatar
MK 82
Talk to these guys doing these coil over swaps. Should be lots of springs laying around. Cunningham will be done sometime this century.
Eddie
Old Jun 1, 2010 | 02:07 PM
Bondami's Avatar
Bondami
St. Jude '13
Well I would guess they are gonna hit you for an hour.. since thats what the book calls for.. so about 70-90 bucks.
Seriously if you have a few minutes and a basic set of handtools you can change it in nothing flat. Jack it up, two long bolts on the outside and 4 small ones on the inside, pull the shims and spacers out, put the new spring in, four bolts in the middle and the two long ones on the outside.. all done. no spring compressors or anything like that.. a jack two jacktands and a couple wrenches. Gotta be the easiest spring i have ever changed. and while your at it.. get the longer bolts from VB&P and you are all set if you want to lower the rear end later.
Old Jun 1, 2010 | 03:00 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Contact Vette2Vette for an used monospring, compare prices and make a call.
To rear leaf spring broke
