fuel filter brands
Old Jun 3, 2010 | 12:46 AM
Waspination's Avatar
Waspination
Default fuel filter brands
Whats are you guys using today for fuel filters? Whats a safe bet?
I know fram has gone to **** so none of those.
Reason is im about to change mine, got slight miss when running idle, seeing if fuel filter will help but dont even know how old it is so gonna change it anyway.
THX guys!
Old Jun 3, 2010 | 12:49 AM
samsonb's Avatar
samsonb
Napa Gold.
Old Jun 3, 2010 | 02:09 AM
pmihaltian's Avatar
pmihaltian
Slingshot
1985-1996 ACDelco Gas Filter #GF652
Old Jun 3, 2010 | 02:13 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Originally Posted by Waspination
Whats are you guys using today for fuel filters? Whats a safe bet? Reason is im about to change mine, got slight miss when running idle, THX guys!
You might want to clean your throttle body & try some fuel injector cleaner.
Old Jun 3, 2010 | 07:37 AM
78pacer's Avatar
78pacer
Bingo...NAPA or AC\Delco.
Mike
Old Jun 3, 2010 | 07:41 AM
Pete K's Avatar
Pete K
Once my dealer stopped selling AC-Delco, I switched to Purolator. They seem as good as any I guess.
Old Jun 3, 2010 | 07:47 AM
Muffin's Avatar
Muffin
At one time Purolator made many filters, all types, for AC Delco. Not sure about today.
Old Jun 3, 2010 | 08:36 AM
Joe C's Avatar
Joe C
i replaced my 90's fuel filter with a "made in the USA" ACDelco piece. other brands will work okay, but i'd stay away from any, plain white box, "made in china" crap. trying to save $5 here just ain't worth it...
Old Jun 3, 2010 | 09:41 AM
Aardwolf's Avatar
Aardwolf
The diesel guys were saying good things about Baldwin filters. The micron rating was good. Check you filters rating and flow rate to compare. I believe stock was something like 10 microns and 90 gpm. I put in a reusable filter that flows 330 gpm and filters 10 micron.
Old Jun 3, 2010 | 11:14 AM
WW7's Avatar
WW7
It could be your filter,but if its not missing at higher RPMs it should be getting enough fuel at idle..Clean your IAC and the housing and do whats suggested above. Could also be wires.plugs,cap,rotor,injectors, many things it could be.. You need to go through the basics first..WW
Old Jun 3, 2010 | 04:07 PM
Waspination
i tried techron, but still got it. Just changed plugs. Wires are next after fuel filter. Im gonna do one at a time to see what fixes it. Injectors all click but dunno if any are not up to par or how old those are. As far as the distributor cap and all those components go, i wouldnt know what to look for to see if it is a problem cuz i never dealt with them before.
IAC... I never cleaned it. How would you go about that?
Old Jun 15, 2010 | 09:29 PM
Waspination
finally got fuel filter changed. Was tough but got it done. took hour and a half cuz its a first for me. Old one was definitely dirty.
GOT NAPA GOLD
Old Jun 15, 2010 | 10:35 PM
90Indy's Avatar
90Indy
Wix oil and fuel filters.
90Indy
To fuel filter brands
