1987 knock sensor location?
Old Jun 4, 2010 | 05:53 PM
Benny771's Avatar
Benny771
Default 1987 knock sensor location?
Can someone show me where it is or tell.
Pics would be great.
I have roller rockers, apparently the sensor can interfere.
Old Jun 4, 2010 | 06:02 PM
c4cruiser's Avatar
c4cruiser
The knock sensor is just in front of the starter just above the oil pan rail. It will be behind a heat shield.
Properly adjusted roller rockers and good lifters should not really cause any problems.
Old Jun 4, 2010 | 06:10 PM
Benny771's Avatar
Benny771
I dont believe it will do any harm to test it disconnected? Do you agree?
At least it will tell me if it is interfering with the set-up.
Old Jun 4, 2010 | 07:56 PM
c4cruiser's Avatar
c4cruiser
Disconnecting the knock sensor will set a Code 43 and can result in sluggish performance. It won't really have any effect in trying to test for noise in the valvetrain.
The whole premise behind this system is to have the sensor detect "knock" and pass the signal onto the Electronic Spark Control module which is the square relay just to the outside of the heater fan motor. The ESC will then shut off voltage to the ECM which results in timing being retarded. This happens above 850 RPM or so.
You will really need a scan tool to do troubleshooting. There will be displays on the scan tool to tell if the sensor is really detecing a noise. There is also a display to show how much spark retard (timing) is being done by the ECM.
To 1987 knock sensor location?
