With headgaskets starting to weep and the rear main seal joining the weeping process, and with 119800 and counting, the time is now to replace the seals and headgaskets, or to go the crate engine route. My vette is a daily driver, stored in the winter. Thoughts?
Unless you have a local machine shop you can really trust, it would be far quicker to go a crate engine route. With a crate motor, the long block is assembled so all you need to do is to transfer the brackets and accessories and stuff the new engine back in
Many crate motor suppliers provide a warranty, something that some machine shops won't do. For example, Jasper remanufactured engines come with a 3 year, 100K miles warranty that is transferable. They also offer a line of performance engines.
You didn't say if you have to go thru smog inspections, but if so, then a stock-type replacement may be the best deal. GM also offers a line or reman motors and the ZZ4 crate motor would be a good upgrade and IIRC, some people have gotten the ZZ4 to pass some state emissions inspections.
From: One day you're a Comet...the next day you're dust... Arkansas
If their is a good local shop I would go with a basic rebuild, refreshing and replacing only what is needed. It will save you money. 120K on one of these cars is not a lot. You may just need new seals and refresh the heads. I would do your research and have the work done this winter. If it were me I would put in a bigger cam and get a tune as well.
C4 of Year Winner (appearance mods) 2019
L98 C4 vette motors aren't really anything special. (Working on them -- inside a corvette -- is a different challenge though.)
You should be able to find a local mechanic who'll rebuild (refresh) the motor for about the same price as a crate motor. IOW, you'd still have to pay for labor to r/r the crate motor.
If you can find someone you trust to do the r/r, they should know (be able to find) a machine shop to do the maching work. If not, that shop ain't worth a crap.
Some shops might be more inclined to use a PACE replacement or something similar. With a warranty on Pace motors (or similar), it's not a terrible option -- especially if you're happy with the stock setup/power.
BTW,,,Vette motors aren't any harder to r/r than the next motor. Don't let a shop try to say they are. If so, move on.
I think in your case a refresh would work out fine depending how much of the work you can do your self which you didn't say. You don't have to R & R the engine to replace the rear main or the head gaskets. I would do a compression test if that is good and you don't have a oil burning issue now. Just have the heads worked new seals & valve job then over the winter R & R the trany and do the rear seal. You could add new 1.6 rockers & valve springs along with new injectors if you wanted for a little performance boost with out getting a new tune.
Good luck on your decission
Thanks for all of your thoughts.
no garage-my shed isn't weather proof. and has no heat.
my mechanical abilities are not up to this type of project.
I live near attleboro, ma and don't have a favorite shop.
If anyone have recommendations, I sure would appreciate them.
Again, thanks.
Again, thanks.
You could try what I did. Post on Craigslist for someone to help pull the motor in exchange for having it. (It would include reinstallation). You might have to add cash depending on your skills to prep the motor for pulling (like r/r brackets, wiring, etc....)
Again, thanks.
Paul, I would ask around and do some local research on a shop in your area. There has got to be someone locally you can find to work on a chevy 350 engine. Their is nothing special about these engines.
If it is not for performance purposes, and not for resale, then just have things freshened up.
At this point it comes down to overall investment, and how it will pay off for you.
IMO spend as little as possible if it is not a priority, and consider the future of the car in your hands.
That is just what I would do in the situation.
Do you belong to a local forum/club. We pulled and installed 2 motors in the last 3 weeks. It is not a big deal if you have someone there who can help and has done it before. A couple of guys who have done it before and if you have a local shop that has a lift you can rent is all you need. A cherry picker and an engine stand you can rent, and in 3 hours the engine is out. Good friends and a weekend you can be back on the road in no time...
Pulling and reinstalling an engine in a C4 is pretty straight forward...
For 1K you could get someone to replace your rear main seal and head gaskets.Unless you drive real hard your engine should go another 119k without needing a rebuild.
I think in his area of the country it would be a little more then a grand to do that work. Remember you will more then likley have to include machine work on the heads at the very least a valve job and new guides given mileage on his engine IMO
