1000 miles now
Old Jun 5, 2010 | 10:29 PM
Marv02's Avatar
Marv02
Default 1000 miles now
After getting my 86 back on the road after buying from the old ownner.
And old ownner had it sitting for the last 7 years with 144800 on it.
I have drove it now a 1000 miles I notice it using oil about 1 quart low.
I changed fluids and all filters before driving the car before I dove the car after sitting for the last 7 years.
It not leaking it's not blowing blue smoke seems to run fine.
Any Ideas where I should start looking Valve seals Rings or what.
I mite do a compresion check in the morning but it cranks over evenly no surging no over heating.
I know the motor getting little tired and I know 1 quart not a lot of oil but I rather fix if I can before it turns in to a tow job to get the car home.
I am planning to go through the motor trany and complete drive line one of these days but I need to save more money up before I do this.
Old Jun 5, 2010 | 10:47 PM
Churchkey's Avatar
Churchkey
One qt in 1K is not excessive. When I was a line tech at a dealer the factory would not honor a oil usage claim unless consumption was a qt in 800 miles or less.
Suggest another brand of dino oil the next oil change. IMHO: High milage cars benefit from Shell Rotella T 15-40.
A few full throttle pulls in a lower gear will help free up the piston rings.
Old Jun 5, 2010 | 10:55 PM
Marv02's Avatar
Marv02
I will try a high Mileage oil anext time nd see what happens I using Castrol 5-30 for now.
I thought Shell Rotella was for trucks.
I use it in one my dirt bikes once I did notice it trun black very quickly.
I have rev the car out but not real hard for a short runs.
Should I let wind it up hard and hold it there.
Old Jun 5, 2010 | 11:28 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
So how you like driving it? Hey, its a Gen 1 small block chevy. They run forever. Enjoy..
Mike
Old Jun 5, 2010 | 11:40 PM
Marv02's Avatar
Marv02
I like the car but it could use some more power.
Still chasing the bugs out of the car.
I been thinking of putting a new crate motor in it and put the stock motor and put in storage in the garage so Have the stock motor if I ever need it.
I don't want a race car but one that can out run a new Toyota car when needed it's a Vett.
Mike
Old Jun 5, 2010 | 11:42 PM
Bondami's Avatar
Bondami
From: Southside of Western Norte Americano State of Confusion, ColoFornia
St. Jude '13
[QUOTE=Marv02;1574299482]I will try a high Mileage oil anext time nd see what happens I using Castrol 5-30 for now.
It is but its a high detergent oil thats REALLY good at cleaning out crud and varnish. diesel oil is meant to clean up the soot that is inherent in a diesel.. it works pretty well and it has more of the zinc and additive package that has been removed form car motor oils..
Should I let wind it up hard and hold it there.[/QUOTE
NO, its been sitting a long time.. give it a chance to loosen up and all the seals and what not to rehydrate.. the rings will loosen up in normal use, you could try a little sea foam pushed into one of the vacum lines that will loosen rings and clean the valves off. (just follow the driections on the can its easy.)
To 1000 miles now
