Gear oil
Old Jun 6, 2010 | 11:53 AM
jbutta's Avatar
jbutta
Default Gear oil
i just finished installing the dana 36 in my 87 vert. then came time to fill it with gear oil. i found some valvoline 80-90 that said limited slip on the bottle. do i still need to put in the limited slip additive, or is it already in there?
Old Jun 6, 2010 | 12:03 PM
samsonb's Avatar
samsonb
Just curious what Valvoline gear oil was it?
Old Jun 6, 2010 | 12:42 PM
jbutta's Avatar
jbutta
i meant to bring the bottle home with me, but of course, i forgot. i got it at autozone. all i remember is it said sae80w-90. then also on the front of the bottle, it said "limited slip".
Old Jun 6, 2010 | 01:17 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
I haven't seen that but maybe the fine print on the back of the container will give you the answer. Since you are a guy I assume you didn't read the directions.
Old Jun 6, 2010 | 07:21 PM
jbutta's Avatar
jbutta
here are pics of the front and back of the bottle.
Old Jun 6, 2010 | 07:22 PM
jbutta's Avatar
jbutta
Old Jun 6, 2010 | 08:56 PM
BADDUCK's Avatar
BADDUCK
MT-1 is the services group for non-syncronized gear sets and heavy service. GL-5 is severe services group and should allow use with most complex applications.
Old Jun 6, 2010 | 09:58 PM
tblt44's Avatar
tblt44
I would get one bottle from GM for 12 bucks and put it in,I did when I put Valvoline in mine
Old Jun 7, 2010 | 04:40 PM
jbutta's Avatar
jbutta
i'm not all that versed in this stuff. does this mean i am good with this fluid?
Old Jun 7, 2010 | 04:50 PM
BADDUCK's Avatar
BADDUCK
I wouldn't trust it just because it says "limited slip" on the label. You could contact Valvoline through their website and pose the question.
Old Jun 8, 2010 | 10:03 PM
jbutta's Avatar
jbutta
i called the valvoline tech support line today. they told me there is limited slip additive in the gear oil. but recommended adding more if car is driven hard, or taken to the track.
Old Jun 14, 2010 | 02:47 PM
samsonb's Avatar
samsonb
I believe you'll still need to add the GM additive anyways. As I had read those type of bottles only contains 2 oz of additive, and that is what the tech said on the phone. So, since you won't use up 2 full bottles, you'll run up short on 4 oz of additive. The tech also said adding the 4 oz of additive won't cause any problems.
The tech also said the synthetic that is in the Durablend and Synpower will eat silicone. And mentioned something about RTV. I know the case is sealed with something like RTV. So, I think I'll just go with the regular Valvoline 80w-90 in the white bottle.
To Gear oil
