Valve cover emblem
Old Jun 9, 2010 | 12:48 PM
ffvetteman's Avatar
ffvetteman
Default Valve cover emblem
Whats a good glue to re-attach my vavle cover emblem to the valve cover? I want it to stay on there.
Old Jun 9, 2010 | 01:33 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Bazoka Joe gum...
No, use epoxy. There are different kinds, buy the one for plastic/high temperatures. I used one that comes with the two-injection method, you mix it, apply and it's dry in 5 minutes. That stuff is GOOD!!
Old Jun 9, 2010 | 02:26 PM
pmihaltian's Avatar
pmihaltian
Slingshot
I used inexpensive Epoxy from Harbor Freight on mine. Been on for 6-7 months and seems to be ok.
Old Jun 9, 2010 | 04:13 PM
LD85's Avatar
LD85
2 component epoxy
Old Jun 9, 2010 | 04:31 PM
engle1147's Avatar
engle1147
For the L98's stock aluminum/magnesium covers and a metal emblem I used JBWeld to bond the 2 pieces.....been a over a year now and that puppy is still stuck on there good-n-tight.
Old Jun 9, 2010 | 04:54 PM
ejscarfo's Avatar
ejscarfo
I used a 2 part epoxy from Gorilla Glue. Its holding fine more than a year now.
Old Jun 9, 2010 | 06:45 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
IIRC the factory emblems on my 92 had two sided tape. The replacements I put on came with two sided tape as well.
No problems with either set coming loose.
Old Jun 9, 2010 | 09:14 PM
Al Borman's Avatar
Al Borman
Like others have said, JBWeld. Scuff up the mating surfaces to give the epoxy something to bite into......
Old Jun 9, 2010 | 09:28 PM
floridamale's Avatar
floridamale
Old Jun 9, 2010 | 11:30 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
To Valve cover emblem
