Lt1 Roller Rockers
Old Feb 28, 2017 | 01:45 PM
Teothe1nonly's Avatar
Teothe1nonly
Originally Posted by STL94LT1
I've ran both Crane Gold 1.6 SA rockers and Comp Cams Pro Magnum 1.6 SA RR's. Both a high quality rocker, only difference was the Cranes were a bit quieter.
Currently I am running Comp Cams' 1.6 non self-aligning Pro Magnum roller rockers with TrickFlow guide plates and Chromemoly pushrods. You should consider a similar setup for a more stable valvetrain and future engine mods.
I just ordered what you said your running. The part number is cc 1605-16. They are non self aligning and I also order3d the trickflow guideplates and chromoly pushrods. Can you please verify the rocker part number for me please, because summit doesn't state that it's for an lt1
Old Feb 28, 2017 | 08:38 PM
STL94LT1's Avatar
STL94LT1
Those rockers will work. Doesn't have to be LT1 specific.
If you haven't already ordered, you'll also need 7/16 rocker studs. I'm using ARP studs.
Old Mar 1, 2017 | 02:06 AM
Teothe1nonly
ordered the studs too...thanks so much for actually being awesome and responding. Can't wait until install. Next week I'm doing the rockers and my electric mezere wp118hd pump is on its way so I'll bang out both.
Old Mar 1, 2017 | 02:09 AM
Teothe1nonly
1 more question, I couldn't find out if my 96 composite valve covers will need any modification or they will clear no problems with the ultra pro magnums?
Old Mar 1, 2017 | 03:15 AM
STL94LT1's Avatar
STL94LT1
Pretty sure those valve covers will work without modification.
Old Mar 2, 2017 | 05:47 PM
ChrisWhewell's Avatar
ChrisWhewell
I ran chevy brand bowtie roller rockers 1.6 with the bowties stamped on them in my 93 about 8 years using stock valve covers, no problem.
Old Mar 3, 2017 | 05:13 PM
aboatguy's Avatar
aboatguy
If they are like my 95 LT1 composite valve covers I removed the drip tabs to clear my (pro-magnums?, this is an old thread and its been a long time) the good new is it literally took a couple of minutes to remove all the tabs
