Is the LT1 reliable?
Old Jun 9, 2010 | 06:52 PM
mundo's Avatar
mundo
Default Is the LT1 reliable?
I'm new to the LT1 community. My C5 has an LS1, very reliable. My '84 had an L83 with Crossfire. Very reliable, funcky looking induction setup but very reliable.
The previous owner put a ton of money into this car getting it repaired. I think some of was the shop ripping him off. A reply to one of my other posts talked about all the things he changed on his LT1 C4. Leads me back to my question, are these LT1 engines reliable? Anything to look out for? From the tranny back it's basically the same car as my '84 Vette.
Old Jun 9, 2010 | 07:22 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
150k on mine
what did he have done?
Old Jun 9, 2010 | 07:30 PM
mundo's Avatar
mundo
The engine has 176K. Opti-spark, radiator, hoses, water pump, rear main seal, injectors, ecm, ASR. Just to name a few things. It uses synthetic oil (10w30). One of the reasons I bought it is he replaced all of these things.
Old Jun 9, 2010 | 07:34 PM
MK 82's Avatar
MK 82
Originally Posted by BrianCunningham
150k on mine
Are you saying you have poured $150K into your C$?
would love to see that itemized list!!
How much of it has made it's way onto the car?
Old Jun 9, 2010 | 07:53 PM
STL94LT1's Avatar
STL94LT1
Pretty sure it is 150k miles.
Old Jun 9, 2010 | 08:23 PM
SJW's Avatar
SJW
Very reliable. The only potentially weak component is the distributor (aka Optispark or just "opti"), but don't let it scare you. It's a distributor, nothing more, nothing less, albeit an advanced one (no pun intended). The chief problem with the Opti is its placement under/behind the water pump. This makes it somewhat vulnerable to getting a coolant bath, which will nearly always kill it, and also makes it somewhat more challenging to service, as quite a few items need to be removed to gain access to the unit.
There are many LT1s out there that have gone a lot of trouble-free miles.
Live well,
SJW
Old Jun 9, 2010 | 08:41 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
I have had 2 Corvettes, 3 Impalas, and 1 Z28 with LT1's.
I never had any problems with them except I had to do a water pump in the Z28. I have 128k on my current 94 Corvette and have had about the same on a couple of Impalas.
My experience is that they are very good and reliable motors.
Old Jun 9, 2010 | 08:55 PM
MK 82's Avatar
MK 82
Never mind!
Old Jun 9, 2010 | 09:01 PM
aboatguy's Avatar
aboatguy
Had more than 150K on my Impala SS....and it was running fine when Insurance company totaled it due to some rear end damage.. God I loved that car....
I drive my 1995 C4 all over...sometimes more than 1,000 miles in a day (I love road trips).
Old Jun 9, 2010 | 09:28 PM
tblt44's Avatar
tblt44
Its a chevy small block very reliable
Just don't give the opti a bath
Old Jun 9, 2010 | 11:08 PM
dreamer2468's Avatar
dreamer2468
St. Jude Donor '09-'10-'11
I have over 150,000 on mine and counting.
I recently had similar work done on mine as it developed an oil leak that we couldnt locate, so I took it to a highly respected Corvette mechanic here locally who also happens to be a member of the forum.
He replaced all my gaskets, as well as I had him put in a new opti because the water pump had to be replaced anyway, as well as new plugs and wires, new pulleys, a fuel filter and a 160 degree thermostat as it was running extremely hot.
The water pump that I had just purchased turned out to be a faulty one.
It runs like a top now, and plenty of power left.
Old Jun 9, 2010 | 11:22 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
I'm on my third LT engine.
...YES
11 seconds of LT1 reliability proof.
Old Jun 10, 2010 | 12:28 PM
Warren Seale's Avatar
Warren Seale
Even if the Opti doesn't get wet or dripped on, sometimes the optical sensor module inside (made by Mitsubishi) goes kaput. When this happens you wind up replacing the whole thing.
Warren
Old Jun 10, 2010 | 12:54 PM
runner140*'s Avatar
runner140*
Some of us have as much as 200,000 to 300,000 miles...is that reliable?
I only have 180,000. Its a matter of maintenance and not what type of was used.
This LT1 has got me to work every day for the last seven years.....25 miles each way...rain or shine.
Old Jun 10, 2010 | 01:03 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Heck yeah! Mine's only flatbedded me once in 10 years and 120,000 miles of ownership. And that was due to a coil that was left installed wayyyyyyy past its maximum service life (my fault).
Old Jun 10, 2010 | 01:16 PM
engle1147's Avatar
engle1147
Yes very reliable and quicker than you'd think as well.
Here is stock LT1 with a couple of bolt-ons in video below J/K
Old Jun 10, 2010 | 01:31 PM
onedef92's Avatar
onedef92
Even in stock form, my LT1's surprised many a **** thinkin' it was just a "lowly C4." The first time mine got rubber from a WOT kick-down at 60 mph, (A-4 auto) it actually surprised me, too.
To Is the LT1 reliable?
Old Jun 10, 2010 | 01:56 PM
runner140*'s Avatar
runner140*
But it felt like $150k.
Old Jun 10, 2010 | 01:59 PM
BrianCunningham
sure does
Old Jun 10, 2010 | 06:14 PM
Akcelr8 N VA's Avatar
Akcelr8 N VA
Overall, LT1s are very reliable, with one word of caution. I had over 40K track miles on mine before it blew. High rpm, chop throttle and a tight turn killed it. It probably would have lasted much longer if I had a road race oil pan and accusump... lesson learned. If you plan to track the car, get rid of the stock pan for a baffled road-race pan (Canton or similar) at a minimum.
