Ars
Old Jun 9, 2010 | 07:11 PM
Hippie's Avatar
Hippie
Default Ars
Hello! My first post, first Corvette, first problem. Hope I can get some help and give some one day if I can. Driving last night engine stumbled quickly ARS light came on but ran fine till home. Today, started fine drove about one mile engine went dead ARS light on. Had to be towed home. Turns over, sometimes acts like its trying to start.93 six speed 75K Thanks for any help
Old Jun 9, 2010 | 07:31 PM
Joe C's Avatar
Joe C
hello noob with his first post - welcome to the nut house!
first of all, are any codes set? seems there's something like 29 codes related to the ABS/ASR system. i'm looking at my "corvette ABS/ASR operation and diagnosis" manual, and i don't see anything what would cause a complete shutdown. it might be ECM related - i'll keep looking through the manual and see if anything jumps out...
hang in there. there's a lot of smart people on the forum - someone will figure this out...
BTW, try to get a copy of this manual -
Old Jun 9, 2010 | 07:40 PM
Hippie's Avatar
Hippie
Thanks. I was just looking see how to pull the codes.
Old Jun 9, 2010 | 07:53 PM
Hippie's Avatar
Hippie
I got a code 42. Does that tell anything.
This is what I found poking around on GOOLGE
42 Check wiring at ignition module. Replace ignition module. Possible ECM failure.
Old Jun 9, 2010 | 08:02 PM
glassman74's Avatar
glassman74
This is code 42 for 92-92. Hope this helps.
The EST circuit voltage was below 0.5 volts when engine speed was below 3000 RPM.
glassman74
Old Jun 9, 2010 | 08:10 PM
Joe C's Avatar
Joe C
code 42 doesn't seem to be a ABS/ASR related code - ??? the ASR light just may be a coincidence. for grins and giggles, disconnect your battery for about a half hour. see if that helps...
Old Jun 9, 2010 | 10:43 PM
Hippie's Avatar
Hippie
I checked to see if gettig fire with timing light(crude method) No fire. I'm a working slob will try more tomorrow. thanks for your help.
Old Jun 15, 2011 | 12:07 AM
svxfiles's Avatar
svxfiles
4th Gear
I am new to this forum, and I appreciate all of the knowlege and experience that you share.
I would like to share something that might help someone with a ASR problem...
While working on John L's 1996 LT1 Corvette,
(after installing a Jet Technologies Supercharger, 40# injectors, Trifecta Reflash, Maganflow hi flow cats, Flowmaster exhaust, Jacobs ignition,)
for no apparent reason the ASR off light, Service ASR light, and Service engine soon lights came on.?!?!?!
It turned out that the brand new TPS went bad after about two weeks after I installed it?!
Showing 0V at idle it kicked on the ASR code.
More later.
Tom
Old Jun 15, 2011 | 12:28 PM
myk7's Avatar
myk7
That's not always a good way to check for spark, mine won't run a timing light unless it's running. Pull a plug wire, stick a plug in it and lay it on a ground somewhere, then check for spark while cranking.
To Ars
