Soft Brake Pedal
Old Jun 10, 2010 | 07:39 AM
petdoc's Avatar
petdoc
Default Soft Brake Pedal
My 96's brake pedal suddenly started requiring a couple of pumps on the pedal to get some pressure behind it. At first depression it will go about half way to the floor....a couple of pumps later it works fine. 5 minutes later, it's soft again. Is this a brake booster issue? And if so is there a "how to" thread on replacing the booster????? Thanks, Lee
Old Jun 10, 2010 | 08:31 AM
vette079's Avatar
vette079
Sounds almost like a leak in the MC.
Check the brake fluid level first.
Old Jun 10, 2010 | 08:53 AM
runner140*'s Avatar
runner140*
The usual test.....hard pedal=bad brake booster
soft pedal=air in the lines or bad master cylinder or system needs a complete flush.
Old Jun 10, 2010 | 10:48 AM
kangi's Avatar
kangi
Old Jun 10, 2010 | 11:38 AM
dogfish246's Avatar
dogfish246
Old Jun 10, 2010 | 03:45 PM
pcolt94's Avatar
pcolt94
The seals in the master are probably shot.
Get yourself a master before you need front end work.
To Soft Brake Pedal
