Base manifold bolts???
Jun 10, 2010 | 06:27 PM
I am removing my base, and the manifold bots are either very very tight, or they are seized in.
How much pressure does it take you guys to get yours out?
I have never experienced this type of torque on an engine intake before, and I am afraid to strip the head, or break the bolt off in the head.
I am soaking them with PB blaster, but I only got one free so far.
Any input?
Breaker bar/ impact wrench
Jun 10, 2010 | 06:29 PM
sometimes.. If you tighten them a little they will break loose. GL
Jun 10, 2010 | 08:23 PM
Tomorrow is time for light impact I guess.
Jun 11, 2010 | 02:39 PM
How did they come out? I used 1/2" Drive on mine
Jun 11, 2010 | 03:18 PM
Quote:
Originally Posted by
Pwnage1337
I used a half inch also, but it did not work. it even took a little while with the impact, this morning, so I can't believe I did not break any.
I did have to pound a T45 in to 2 of them, but then they came out fine after that.
I have no idea how in the hell that thing was on so tight.
Mini is now on, and being all hooked back up, except I dropped the dizzy clamp some where
Jun 11, 2010 | 03:36 PM
Intake bolts only should be torqued to around 30ft-lbs or so. Who put the manifold in?
Jun 11, 2010 | 04:09 PM
383vett
Thats what I was thinking.
I wish I would have replaced my Torx bolts with some SS .. You might consider that while you have them out.
Jun 11, 2010 | 04:41 PM
383vett
The base was in the car already, When I put on my SR I just used runners, and plenum, because the base was ported, and already had the egr plate, and stuff.
I don't know who did that, but I hope that is not from a shop, because the previous owner, was an old man that had a "mechanic".
All of the gaskets, and stuff wre new when I got the car.
Thank god I did not break or strip one.
Oh yeah, they also had the whole bolt covered in RTV all the way down too. Not a smear, but a coat of that crap.
Jun 11, 2010 | 06:24 PM
pologreen1
Unfortunately people at a shop are not working on their own car and don't take the care that we do. I have seen it a million times Techs using air rachets and not following torque specs.
I think I was the only one who used torque sticks when I was a tech.
Jun 11, 2010 | 06:58 PM
pologreen1
Its probably in the lifter valley.
Jun 11, 2010 | 07:25 PM
JackDidley
It fell behind the motor, I'll find it, or get a different one.
Jun 11, 2010 | 09:32 PM
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
I sprayed WD-40 overnight and next morning I removed them with an open wrench.
Is your engine out? If it still in the engine bay, how are you going to use an impact gun?
FSM states, Manifold bolts: 30 lbs ft
Jun 11, 2010 | 10:35 PM
PLRX
It is an L98, and I had to use an impact to get the manifold bolts the hold the intake to heads out.
They were soaked for 24 hours with PB blaster, and I worked on them, then this morning I figured I had to resort to the impact.
They all came out, and the miniram is on.
Jun 11, 2010 | 11:05 PM
pologreen1
I have a Camaro that eats tools back under the distributor. Like a black hole or something.
Good thing I only open the hood once a year.
