I am putting on my miniram right now, but the one I bought has four (2 on eft side, 2 on right side) barb fittings underneath the center of it it. One of them has the fuel reg hooked up to it.
(I took some pics, I will get them up soon)
Did anyone else use these?
Can I assume it does not matter what foes to each vac line, so long as it gets vac?
I suppose I could pull them out, and reuse what stock fittings there were, but not sure what is best.
Is one of them for the brake booster, and the other fitting on the passenger side by the dizzy on the stock manifold too?
