Computer for new 383 stroker?
Old Mar 20, 2002 | 07:07 PM
BMH95's Avatar
BMH95
Default Computer for new 383 stroker?
Where should I go for a computer, or should I go DFI? I have a healthy stroker, and I know the motor specs. I haven't bought the exterior components (fuel, ignition, intake, etc).
Old Mar 20, 2002 | 07:37 PM
yoslambo1@cs.com's Avatar
yoslambo1@cs.com
Default Re: Computer for new 383 stroker? (bmh95)
im doing away with my computer & fuel injection. i put a airgap intake & holly 750 carb on. not only was it less exspensive but it just simplified things. :yesnod: good luck whatever you choose. :cheers:
Old Mar 20, 2002 | 07:41 PM
J Z06's Avatar
J Z06
Default Re: Computer for new 383 stroker? (yoslambo1@cs.com)
Sorry Eric, :U Is what I say to carbs...they may be simpler to work on..but I still don't care for them.
you could get lucky like beach bum or ralph whom both have a mail order formato chip(I think) Or go with a DFI and the right person tuning it. If I had to do it over again, DFI would have been my first choice. There is an ingenious tuner close by.
Old Mar 20, 2002 | 07:47 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
No reason for you to go DFI or any computer system other than just reprogramming your stock setup.
Old Mar 20, 2002 | 09:24 PM
Thumper's Avatar
Thumper
Default Re: Computer for new 383 stroker? (Vette92)
Why are you looking to change the computer? On a '95 you can have yours reprogramed to handle a 383.
Old Mar 21, 2002 | 05:56 AM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
I'll third the recommendation to keep the stock ecm. The maf setup can handle up to about 550 NA hp and the ecm goes up to 6500+ rpm. You will probably want to go to 30 lb injectors unless you are exceeding 480 hp in which case 36 lb.
Old Mar 21, 2002 | 11:55 AM
BMH95's Avatar
BMH95
Default Re: Computer for new 383 stroker? (AquaMetallic94LT1)
I'm not planning to get a new computer if I don't have to, but I need to know where to send the stock computer to have it reprogrammed. I also need some help finding out what fuel and intake and other components to get so I have a good matched setup.
Old Mar 21, 2002 | 12:34 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
I also responded to you other post about the other items you were looking for. A huge part of a good setup depends on how good your heads are.
Chris
Old Mar 21, 2002 | 01:40 PM
Timmy!'s Avatar
Timmy!
Tune it yourself! Refer to the ECM/PCM tuning section here on the forum. Or you could send it off to Ed Wright (fastchips) or I think Chris B at SpeedDemon Motorsports might do tuning too.
Welcome to the 383 club!
To Computer for new 383 stroker?
