Interior Lights - No Shut Off
Old Jun 11, 2010 | 05:14 PM
VA50th's Avatar
VA50th
Default Interior Lights - No Shut Off
96 Coupe LT1
The interior lights do not shut off.
I checked the radio and it does shut off when you open the door.
I checked the door plungers and they seem to be fine.
What else should I check?
The PKE is acting strange to the point where I don't hear the horn sound or the doors lock as I walk away. Started this morning at work. Had to come back to the car, open and close the door for it to sound.
Old Jun 11, 2010 | 05:17 PM
94z07fx3's Avatar
94z07fx3
You're 100% sure that the dimmer switch is not fully CCW (top)?
Old Jun 11, 2010 | 05:25 PM
VA50th's Avatar
VA50th
....you're there!
It's the dimmer switch....but I've always had in the full up top position. To get the light to shut off I have to slide it back a bit...but then the lights stay off even when you open the door..??
Old Jun 11, 2010 | 05:52 PM
94z07fx3's Avatar
94z07fx3
With the ambient light sensor blocked off, the dimmer mid-stroke, and doors closed, will it light the lights if you lift up on the outside door handle?
Old Jun 11, 2010 | 08:12 PM
VA50th's Avatar
VA50th
...well it seems to be working ok now. Just went out to the garage (dimmer switch was still just below the top where I left it to get the light off), key in pocket, the doors unlocked, and interior lights came on. Opened door...closed door...walked away...doors locked..horn sounded...then lights went out.
I did notice and then has been happening for a few days, that the door lock/horn doesn't always activate. I then have to walk back to the car, open door, close and try it again. Bad battery in the key remote?
Still don't understand how the lights decided today to stay on even though I've had the dimmer in the max and beyond since day one. Never a problem before.
Old Jun 11, 2010 | 10:21 PM
94z07fx3's Avatar
94z07fx3
I consider myself lucky to get more than two seasons out of the fob battery.
I hope the gremlin stays gone for your '96!
To Interior Lights - No Shut Off
