Changing Themostat
Old Mar 20, 2002 | 07:47 PM
Dolfan's Avatar
Dolfan
Default Changing Themostat
I've read that most people change the stat to a 160 or so to help with engine cooling/performance. I live in Atlanta and would love to bring down the temp a bit. But how will this help? Once the coolant reaches 160 and the stat opens the rest of the coolant is introduced to the circuit and will be heated. Ultimately the temp will reach operating temperature regardless of the stat. How will this mod keep the temp cooler? :confused:
Maybe I'm forgetting something but I just don't get it. Someone set me straight. :confused:
Old Mar 20, 2002 | 08:00 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Changing Themostat (Dolfan)
Basically you are correct!
But introducing a full flow of coolant at a lower temp seems to stabilize the temp at a lower level (less latent heat build up in the block and the oil temp)
Plus when temps do run up to 200 plus, on the cool down, the thermo will allow temps to move back down to the 170 level, whereas with a stock thermo they remain at 185 plus
Personally, no scientific reason, I prefer 180 degree.
:seeya
Old Mar 20, 2002 | 08:31 PM
rcolling's Avatar
rcolling
For it to be effective you have to adjust the fan temps also. Instead of turning on at 230 degrees have them turn on at 200 and off at 185 for a 180 stat.
Old Mar 20, 2002 | 08:50 PM
65Z01's Avatar
65Z01
Operating temp is determined by the thermostat. Ideally the engine will maintain the coolant temp at the point (approximately) where the stat opens. Once the stat is open the coolant flows freely carriying heat from the engine and expelling it into the atmosphere in the radiator. There is adequate air flow through the radiator at highway speeds; a complimentary temp fan sw maintains air flow and so coolant temp in city driving.
I prefer the 160 deg stat and fan sw since I want all the extra HP possible, as every 30 deg drop in temp is worth about 10hp more.
Old Mar 20, 2002 | 09:26 PM
Dolfan's Avatar
Dolfan
Default Re: Changing Themostat (65Z01)
Thanks for the insight, What is the stock thermostat temp? In Atlanta I do need some warm up for winter but I deal with much more heat. I guess I should go to the 180 with a switch for all-year driving.
Is the switch from Zips the one people are usng or other brand?
Old Mar 20, 2002 | 10:50 PM
CFI-EFI's Avatar
CFI-EFI
That applies to the temp of the inlet air used for combustion. A hotter engine is more thermally effecient. That is why our engines run so hot in the first place.
Old Mar 20, 2002 | 11:13 PM
VetteNoob's Avatar
VetteNoob
I believe the stock stat is 195 degrees. At least that is the case on my 86.
Old Mar 21, 2002 | 10:40 AM
kkonen's Avatar
kkonen
Default Re: Changing Themostat (VetteNoob)
L98's have a 195 thermostat and LT1/4 have 180 thermostats from the factory. I noticed a drop in gas mileage when I went with the 160 thermostat. LT1's do not like heat for power. You will get an easy 5 rwhp from this mod. For only $20, it is definitely worth it. With the old thermostat my highway temp was 193. It is now 173. To take full advantage of the thermostat you should get a fan switch or reprogram the fans, but you will see a benefit even if you don't. I haven't run the car in stop and go traffic in 100 degree heat yet, but I will get that chance this summer.
Your car will still get hot enough in winter. The thermostat will just take longer to open since the coolant will start at a lower temperature. It will eventually hit the same operating temperature.
To Changing Themostat
