A.c. Question
Old Jun 12, 2010 | 03:01 PM
gcpoe10's Avatar
gcpoe10
Default A.c. Question
I have a 94 LT-1 Corvette, And the A.C. Clutch is not turning on? I have 12V. To the clutch, Can i change the clutch or do i have to replace the compessor too? Thanks Gary.
Old Jun 13, 2010 | 02:37 PM
RLG's Avatar
RLG
You need to find out why it's not engaging.
I think on some models you have 12 volts and the compressor grounds to engage.
freon level ok?
Old Jun 13, 2010 | 06:55 PM
gcpoe10's Avatar
gcpoe10
No freon level is very low, will that keep it from engaging? thanks Gary
Old Jun 13, 2010 | 09:28 PM
vette88racer's Avatar
vette88racer
Cruising
Yes if your low on freon it will keep the clutch from engaging. Its designed to protect the compressor from burning up. I would suggest recharging the ac system to the proper capacity and add dye to the system. If the freon is leaking out you can trace it with an UV light and the yellow glasses.
Old Jun 13, 2010 | 09:50 PM
gcpoe10's Avatar
gcpoe10
Awesome!! Thanks soooo much. Gary
To A.c. Question
