A magic bullet.....
Old Jun 12, 2010 | 03:58 PM
runner140*'s Avatar
runner140*
Default A magic bullet.....
When we overheat, the drill is simple: new radiator cap, a new t-stat,
new radiator hoses and a flush and new mixture of anti-freeze and distilled water AND clean your radiator.
The last item was always the bitch...pull the radiator.
Pics next week. Three and a half foot section of 1/2" PVC pipe. A pipe cap on one end and on the other end, a connector/female garden hose connector. Cut a one inch slice near the end that has the cap with a multifuntion power tool. Cement the connectors on the pipe with PVC cement. Hook up the garden hose to the connector and insert the contraption into the inspection port on the right side of the radiator. Turn on the hose and sweep.
It took ten minutes to do the radiator/A/C. It runs 15 degrees cooler now.
Old Jun 12, 2010 | 04:17 PM
toptechx6's Avatar
toptechx6
Sounds like a good idea, I made a similar rig using 3/4" PCV I use the same way to vacuum that area of debris between the full rip cleaning procedure. Low tech duct tape attachment to the shop vac.
Old Jun 12, 2010 | 05:01 PM
94z07fx3's Avatar
94z07fx3
Similar in concept I made a blow gun snozzle out of 1/4" ID tube with a 90 degree bend in the tip. It still takes some time to work it over as much of the rad as I can reach through the cut outs for the AC lines.
Old Jun 13, 2010 | 11:42 AM
ks5shooter's Avatar
ks5shooter
St. Jude Donor '10-'11-'12-'13
Nice
Old Jun 14, 2010 | 12:35 AM
jfb's Avatar
jfb
C4 radiators get clogged up at their bottom by road debris, straw, plastic bags, usually small stuff that sticks in the radiator, cutting off air flow. Clean it out and you've got a new car!
Old Jun 14, 2010 | 09:51 AM
BerniesVette's Avatar
BerniesVette
I installed a wire mesh screen across the mouth of the intake area. Keeps the trash out of the rad and condenser. Now trash is not a problem.
Bernie
To A magic bullet.....
