push rods how long
Old Jun 12, 2010 | 10:00 PM
gregs86's Avatar
gregs86
Default push rods how long
hello just thinking someone may have the same set up
I have the zz4 short block with AFR 180 heads with a roller cam from tpis it hasnt arrived yet or should i just get a adjustable push rod and test it figure somebody would have the answer
Old Jun 12, 2010 | 11:19 PM
John A. Marker's Avatar
John A. Marker
I used hardened push rods from summit...part number SUM-1457200 they are 7.2 inches. Stock is 7.8 inches. You have to use the shorter rod because of the total height of the roller lifter.
Old Jun 12, 2010 | 11:25 PM
Pete K's Avatar
Pete K
Mock it up and measure it. If the AFR have valve lengths that are .100 longer than stock, you will need something in the 7.300 range. Nevertheless, don't guess.
Old Jun 12, 2010 | 11:42 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
That's probably not too far off. Mine were angle-milled 9cc. At .008" per cc, that's .072" removed. My 195's ended up taking 7.2" (with that much removed). IOW, mine were milled close to the same amount as you think should be added.
(I'm going under the assumption that AFR uses the same core before CNC'ing the 180/195 heads.)
Old Jun 12, 2010 | 11:47 PM
tpi 421 vette's Avatar
tpi 421 vette
The hyd roller engines have a stock length of 7.200" The flat tappet cams came with a 7.800" length. If you are running the stock ZZ4 cam, there is a good chance you will need a 7.200" pushrod. Small base circle cams create the need more than anything for shorter pushrods. And most mild cams don't have a greatly reduced base circle
Old Jun 13, 2010 | 11:35 AM
MK 82's Avatar
MK 82
Just did a cam swap on my LT4. Put in a CC503. Had to go from 7.2 to 7.1. Using the adjustable pushrod is the right way.
Old Jun 13, 2010 | 06:23 PM
JAKE's Avatar
JAKE
DO NOT rely on what someone else is running. Measure then buy what your combination calls for.
Jake
My son, Ryan M. Cameron, graduated from West Point on 22 May 2010! He was commissioned as a 2nd Lieutenant and I pinned on his first pair of "Butter Bars" PROUDEST DAY OF MY LIFE!!
Old Jun 13, 2010 | 06:44 PM
surfer93's Avatar
surfer93
w/Jake.
BTW: Congradulations to your son Jake.
Old Jun 13, 2010 | 07:56 PM
John A. Marker
7.2" should work for you. Same engine as mine (ZZ4) with AFR 180 heads (same as mine). Cam should not make a difference. Roller lifters should be the same height.
Old Jun 13, 2010 | 10:57 PM
gregs86's Avatar
gregs86
thanks for the feed back will mock it up and check it congrats to your son mine just graduated high school
Old Jun 14, 2010 | 12:31 AM
Movnviolation's Avatar
Movnviolation
Contact Jim at TPIS. He can tell you what you need to know. He set me up. I used stock length hardened. See my profile.
To push rods how long
